dead tachometer - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-26-2009, 04:50 AM   #1 (permalink)
The guy with a maroon 92
n3rdifed's Avatar
View n3rdifed's Photo Gallery
dead tachometer
92 camry v6
tachometer is dead. can anyone show me direction to fix this? could it be like a fuse..or a loose wire or something? it just decided to not work anymore -___- but all the other gauges are working. does this mean i have to replace my whole cluster!!!?!?!
n3rdifed is offline   Reply With Quote
Old 04-20-2009, 01:16 PM   #2 (permalink)
View dokes2's Photo Gallery
4th Generation
I have this question too, except I have a 98 Camry with the 5sfe. My tachometer is dead, pegged at 0. All my other gauges work, and I've already replaced the tach so I don't think that's the problem. Any ideas?
dokes2 is offline   Reply With Quote
Old 04-20-2009, 09:02 PM   #3 (permalink)
slpr1mz FTW :-)
slpr1mz's Avatar
View slpr1mz's Photo Gallery
ok, check your fuse box, both inside car and under the hood... look for anything that isn't obvious.
found out my gause fuse box was labeled "fog" when i don't have fog lights lol...
might as well check everything else since you're there...
if not a blown fuse
it may b the wiring...
i'm not sure exactly how the gen 3 is wired,
but if you look up this link
http://www.toyotanation.com/forum/t59805.html
it show's you how to take out the cluster gauge, which should be really close
to the gen 3...
in the back are connectors... there you can do a visual inspection
and hopefully that helps...
slpr1mz is offline   Reply With Quote
