1994 Camry Neutral Safety Switch Removal
Ever since I bought the car (used) for my daughter the lights on the dash to indicate what gear she was in have been either not lighting or completely out. And occasionally she would not be able to start the car because I believe the same culprit (The Neutral Safety Switch). I have read that a new one costs around $300. And I have read a link that tells about adjusting it. And I have found the link at Autozone, that tells about removing it.
If I was to go to a Pic A Part, or Ecology auto wrecking what do you think would be the minimal tools to take to get one off the car. I assume I would have to remove from below the car, or at a junk yard should I attempt from top down?. I suppose a small flat screw driver to remove Electrical connection, Or I could cut the harness above. There is a nut that holds the Shift Cable, does anyone know the size or would an adjustable fit there?.
Sure wish these little switches were servicable. Daughter is doing a stop by, to get this thing fixed, and thought it would be nice to have another before she stops by. Not sure if just adjusting hers would do the trick. Seems only occasionally she cant startthen takes out of park and back in and it may start.
