Gas milage is crashing at an alarming rate... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-28-2009, 03:23 PM   #1 (permalink)
View kenratboy's Photo Gallery
4th Generation Gas milage is crashing at an alarming rate...
First, Bruce FTW -->
Car is a 1997 with a V6 and 5-speed.
When I bought my car about 5 years ago (75k miles), I consistently got 27 MPG in combined driving. However, in the last year, and recently, my mileage is starting to tank. Filled up today after driving the same sort of routes that gave me 27 MPG, and I got just under 22 MPG (a drop of around 23%). Also, I took a road trip a few years ago and got a (shocking) 33 MPG - same trip and I was around 27-28 MPG.
What the hell is happening!?
I'll give you something to work with:
-It has been very cold (but not sure that is it).
-I just got the clutch replaced (that did not change anything)
-I switched from some decent-performance Falken's to some decent-performance Bridgestone G009's about a year ago (could this be a cause)? Tire pressure is checked regularly.
-Spark plugs were replaced around 90,000 miles, which was probably ~3 years ago.
-To my knowledge, I don't think anything like PCV or other sensors have been replaced.
-Air filter is new, and I replace it more than needed.
-I have not put on 500lbs. since I bought the car.
-No other modifications or adjustments.
-Driving style has not changed much.
-I have not noticed a chance in performance or how the engine operates (everything feels OK).
What should I try first? Are there some simple things I can do myself like checking vacuum lines, changing/checking/cleaning sensors, etc.?
It is not a huge deal now, but if there is something I can do that takes an hour or costs $20 to improve things, I want to do it sooner rather than later.
Thanks!!!
1997 Camry CE V6 5-speed!
Mods: Whiteline rear sway bar & nice tires.
2009 RAV4 Limited V6 4WD
Mods: nothing you would care about.
kenratboy is offline   Reply With Quote
Old 01-28-2009, 05:04 PM   #2 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
Check your ECT sensor. This can be done with an ohm meter. If its malfunctioning, the ECM could deliver too much fuel at normal operating temperature. Has your EGR been cleaned? You could also run some seafoam through the fuel system and vacuum lines.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
Old 01-28-2009, 06:39 PM   #3 (permalink)
View JohnHarlin's Photo Gallery
When was the last time you used fuel injector cleaner
Sometimes it is best to start with the obvious, eliminate that possibility and go on.
During a tuneup I had my air filter changed, my 02 censor changed, everything passed their computer sensors and I still get rotten mileage. Now I'm going to get an old change and use plane old fuel injector cleaner and see what happens. Sometimes after I haven't driven for 4 or 5 days a lot of dirt comes out of the exhaust. I don't know if that means anything or not.
Anyway, it wouldn't hurt to try fuel injector cleaner. The cost would probably be something like $7.
JohnHarlin is offline   Reply With Quote
Old 01-28-2009, 06:59 PM   #4 (permalink)
View toyomoho's Photo Gallery
O2 sensor, changes in gasoline mix (adding more alcohol), softer tires can decrease MPG.
Cold?
Old 01-28-2009, 07:31 PM   #5 (permalink)
Gameroom cash: $303055
To add to what 96paseo and toyomoho have suggested, a slow opening thermostat or one that is stuck in the open position can also reduce fuel economy. Does the car seem to warm up as fast as it used to?
Mike
Old 01-28-2009, 08:04 PM   #6 (permalink)
I'll take a look, is it somewhat easy to do?
I would love some (semi) easy projects to play with. I would be thrilled if an hour or two and a few bucks could fix things.
Even if money was not the issue (burning more fuel), this means I have to fill up more often!
Old 01-28-2009, 08:05 PM   #7 (permalink)
I actually did it maybe 6 months ago, but not convinced its ever been used before that, so maybe it needs some more!
What brand/type should I use?
Old 01-28-2009, 08:07 PM   #8 (permalink)
Cold?
Cold = it has been a very chilly winter compared to the average. My book says I have 3, O2 sensors it looks like, and it appears they are all VERY expensive.
Old 01-28-2009, 08:08 PM   #9 (permalink)
Mike
I think it warms up fine. Not sure how hard the job is, but if its a cheap part and not too hard to do, I might just do it for the heck of it.
Old 01-28-2009, 08:27 PM   #10 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
How cold is cold?? are gas stations now supplying you winter gas? (More ethanol)
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 01-28-2009, 08:29 PM   #11 (permalink)
Well, lots of night well below freezing (0-25 degrees F common at night), but still seems extreme that things would be this bad.
Even when I was in the Bay Area for 3 days (very warm), still had the issue.
Old 01-28-2009, 08:51 PM   #12 (permalink)
rty
Gameroom cash: $298766
View rty's Photo Gallery
If my 97 V6 got 22 mpg I'd be happy. My last tank was 17 mpg. In the summer I can get 22 mpg so the cold does produce a pretty significant drop.
rty is offline   Reply With Quote
Old 01-28-2009, 10:43 PM   #13 (permalink)
cruisn76's Avatar
View cruisn76's Photo Gallery
Go to Walmart/Costco and get Chevron Techron Fuel Injector cleaner.
Google this and you will find many forums talking about it. I say about 60-70% good comments on Chevron Techron fuel injector cleaner
Here is a picture of what it looks like:
http://www.amazon.com/Chevron-TECHRO...=pd_sbs_auto_2
I have used it for about a year now (about 4-5 20oz bottles) and I consistently get good mileage. My only problem is a stuck thermostat during the cold winters. Which is affecting my gas mileage from 600km a tank to about 550km a tank
92 Camry 4 cyl 5 Spd
390,000km, Retrofited Projectors + 6000k HID, 2500k Fogs, SRI, K-Sport Coilovers, TRD Rear Sway Bar, GEN4 Ralco Short Shifter, Alpine 7" IVA-D900, 2 x 10" MTX / MTX 900W Amp
cruisn76 is offline   Reply With Quote
Old 01-28-2009, 11:25 PM   #14 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $348853
View BMR's Photo Gallery
Perhaps your brakes are dragging? See if any of the wheels are hotter than normal after you've driven a while. If a brake is dragging, it'll be uncomfortably hot to touch.
BMR is offline   Reply With Quote
Old 01-29-2009, 07:46 PM   #15 (permalink)
Certifiably Insane
96paseo's Avatar
Its not that hard. You need a multimeter that can measure ohms. You also need to check it twice. Once in the morning so the engine is completely cold. Second, after you've driven it for about 10-15 minutes to get it up to full temperature. The sensor is the green colored connector on your coolant outlet housing. Does your temp gauge get up to 1/2?
