NO Reverse - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-28-2009, 07:35 PM   #1 (permalink)
I got parts aoktoyota.com
malayan's Avatar
View malayan's Photo Gallery
NO Reverse
I am buying a 95 2 door 4cyl auto 155k
Drives fine accept no reverse
I will try the lucas trick to soften the possible bypass
and can I code it to get an idea
I am getting another tranny with it but maybe an easier fix?
Thanks
malayan is offline   Reply With Quote
Old 01-28-2009, 07:37 PM   #2 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
You don't need reverse. Just drive in a circle when you need to turn around.
Chris Crash is online now   Reply With Quote
Old 02-02-2009, 05:51 PM   #3 (permalink)
View camry6's Photo Gallery
I lost reverse on my '93 camry a few years ago. It takes approximately twice the pressure to clamp the clutch pack for reverse, than it does to clamp the clutches for drive. I put 2 bottles of LUCAS trans additive in to soften the clutch pack piston seals, and after a little while and a few thousand miles, reverse was almost completely restored. I used the trans for 3 years afterwards till I found a good replacement, it never did fail.
camry6 is offline   Reply With Quote
Old 02-03-2009, 05:29 PM   #4 (permalink)
malayan's Avatar
Camry6 is Cool
THanks sooo Much
I tried that AND IT WORKED
At first I couldn't really tell.. Then I felt a very little tug bairly....
went for a long drive and occationally would put it in reverse after stopping and it slowly got more and more.
I had already got another used tranny to throw in it but wanted to cheak that out..
Thanks again.... You Rock!
It never coded anything. The tranny guy said that is normal and REVERSE GEAR IS AN INTERNAL PROBLEM
Old 03-19-2009, 06:01 PM   #5 (permalink)
Great to hear the Lucas is working for you!
Originally Posted by malayan View Post
THanks sooo Much
Glad my frustration with my transmission a few years ago can help someone else today! LUCAS WORKS, SPREAD THE WORD!!
Old 03-21-2009, 06:36 PM   #6 (permalink)
View lenjack's Photo Gallery
Yup...circuler driveway is the key.
Any car problem can be fixed with a large enough hammer!
lenjack is offline   Reply With Quote
