negative battery post corrosion - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-29-2009, 01:50 PM   #1 (permalink)
View Manny1337's Photo Gallery
I bought my 98 camry back in august and since then ive had to clean the negative battery terminal becuase of corrosion. the positive gets some corrosion but nothing like the negative one. ive cleaned them both about 3 times and it keeps coming back, ive tried new terminals ive checked the ground and it looks good. any idea on how to stop this?
Manny1337 is offline   Reply With Quote
Old 01-29-2009, 02:01 PM   #2 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
your battery is probably leaking at the post.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 01-29-2009, 02:12 PM   #3 (permalink)
View toyomoho's Photo Gallery
Clean and apply some petroleum jelly
Old 01-29-2009, 05:04 PM   #4 (permalink)
i did each time i cleaned them
Old 01-29-2009, 07:47 PM   #5 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862110
View BamZipPow's Photo Gallery
Like Hajoca said...it's yer battery post. It's leaking...it happens.
BamZipPow is online now   Reply With Quote
Old 01-29-2009, 11:33 PM   #6 (permalink)
anyway to fix this without buying a new battery? will it matter if i just keep cleaning it instead of getting a new one?
Old 01-30-2009, 12:38 PM   #7 (permalink)
View Fruitbat's Photo Gallery
Personal experience - nothing
Mine's been corroding since I bought it, and the prev owned mentioned it has been doing it for at least a couple years before that. So 4 years later, it still starts first try even when it's -40 outside.
Old and Busted: '84 Camry LE <2S-E> || '89 Celica GT-S <3S-GE> || '91 Camry LE <3S-FE> || '95 Camry LE V6 <1MZ-FE>
New Hotness: '08 Matrix XR <1ZZ-FE>
Fruitbat is offline   Reply With Quote
Old 01-30-2009, 12:40 PM   #8 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
Aside from cleaning it, you could try the little felt thing-a-mabobbers. I wouldn't expect miracles but they're certainly cheap. I guess you could probably try to use some fiberglass resin around the terminals too?
May want to double check that it's alright to do though to the battery before attempting it. I'm no chemist so I won't pretend to make assumptions that there's no chemical reaction consequences of the resin on a battery.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 01-30-2009, 01:13 PM   #9 (permalink)
was it the negative terminal though becuase i know its very common for the positive one.
Old 01-30-2009, 01:53 PM   #10 (permalink)
Always the neg. terminal. Positive probably hasn't been disconnected since I've had it
Old 01-30-2009, 01:55 PM   #11 (permalink)
well alright thanks man i guess ill just keep doing what you were doing =P. clean when needed and use it till i get stranded somewhere
