the readings says my HC is too high.....is there a way to try and fix this problem??
i've tried looking and searching but most of them just says
change spark plugs, timing (what is timing???), pvc (what is that??), coil pack (what is that?)...ect...
i came here because most of the things listed, i do not know....i know for sure i need to change the spark plug because i haven't done that since i got the car....but is there any other things to look for???
High HC is caused by unburned fuel. What engine do you have? It makes a difference as to what components to check/replace, but changing your plugs is a good start. Check your air filter too.If you've got the stock air box, just pull the filter right out before you go into the test station. More involved/expensive things like coolant temp sensor, sticking/dirty injectors ( run some injector cleaner through it ) or oxygen sensor can be bad too, even with no check engine light ( happened to me ), but do the easy stuff first.
I always add a few of quarts of methyl hydrate to the gas tank and fill up with premium before getting emissions tested. Works for me to get well below the " average " readings.
as silly as it sounds. make sure all of the vacume lines are attached to the throttle body. i had the same problems and it was simply a hose that was detached from the top of the throttle body leading the my EGR. my strut tower bar knocked it off. just an idea.
So you've got the 3vz-fe. Ok, besides the plugs, change the plug wires, distributor cap and rotor. Check your pcv valve too. Remove and shake it - if it rattles, it's ok, if no sound, nfg. Actually, it's so cheap, just replace it.
As for seafoam, idk because I've never used it ( haven't seen it around here ), but lots of people on here seem to think it's great.
and what is a rotor??? (sorry im noob at engine) and where do i find the pcv valve??
Plug wires are about $80. About $130 if you get 'em from Toyota. I've used "Autolite" brand with good results. Cap is about $15, rotor is about $9.
The rotor is underneath the distributor cap. It rotates and routes the ignition spark to each cylinder in the correct sequence. The contact on it tends to get burnt and pitted with age.
The PCV valve is on top of the rear cylinder bank's valve cover, on the passenger side. It looks like a steel cylinder with a rubber hose on top that goes towards the opposite side.
yeah my car was warmed up before the test, but probably not warm enough i guess....
and new echo....at 25 mph it did past.....thats what im confuse about...i mean is it normal???
oh and i did my spark plugs today....found out that one plug in the back wasn't plugged in all the way so i was a v5 for the longest time...
but it wasn't as difficult as it sounds, "just needs right tools" as my brother says...lol...but i broke the pcv valve so i had to buy a new one, then the old one fell in the hole that it was on top of....
took three or two hours to get that thing out of the hole, but yeah spark plug was easier than taking that broken pcv out...
