Remove Graphite Head Gasket - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-30-2009, 12:49 PM   #1 (permalink)
Canyon Killer
View ekopel's Photo Gallery
Just started working on the heads today, getting em cleaned to start the port and polish job. Problem is, even with a gasket scraper, the remnants of the old HG isn't coming off. I don't want to knick up the heads or the block, considering it could cause a leak down the line. Any ideas?
1MZFE
LOTS OF GOOD 1MZ PERFORMANCE/STOCK STUFF FOR SALE! HERE!
ekopel is offline   Reply With Quote
Old 01-30-2009, 02:31 PM   #2 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
Try a brass wire brush.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
Old 01-30-2009, 02:37 PM   #3 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
you can also use acetone on the metal to help eat the old gasket material away.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 01-30-2009, 03:24 PM   #4 (permalink)
View 5SlowFE's Photo Gallery
Spray-on gasket remover is available too. It goes on sticky like paint stripper, let it sit a while and scrape off. I usually use a razor blade and it won't nick if you're careful. Just go slow and don't force the scraper and you'll never have a problem.
5SlowFE is offline   Reply With Quote
Old 01-30-2009, 04:30 PM   #5 (permalink)
View davemac2's Photo Gallery
Use a scraper that uses a razor blade and go slowly applying even pressure across the blade. It's possible the old gasket will leave an imprint on the head because of some micro-pitting. After scraping, use some gasket remover to soften anything that remains, then use a scotchbrite pad to remove the soft gasket material. Paint remover (ie. lye) is the same thing as gasket remover pretty well.
dave mc
davemac2 is offline   Reply With Quote
Old 01-31-2009, 03:26 PM   #6 (permalink)
Canyon Killer
thanks guys.
Old 02-01-2009, 10:53 AM   #7 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
if you do happend to knick some off the block or head, take it to a mechinist to wack off some meterial if you do knick the block or head and use a HG with that would be + whatever amount of meterial that was taken off, if HG for the camry are made that way
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
Old 02-01-2009, 12:24 PM   #8 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
I did a clean up on a tapped oil pan a couple of days ago and I used a Dremel Wire brush bit and it took that silicone right off. Didn't even leave a scratch.
RichieRichJP is offline   Reply With Quote
