92 Camry transmission - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-30-2009, 02:59 PM   #1 (permalink)
View allegoric1's Photo Gallery
What do these two symptoms mean as exactly as possible instead of "bad transmission"? Singing sound in drive/overdrive around 40 and up and a burnt smelling transmission fluid, but it shifts and acts fine otherwise?
allegoric1 is offline   Reply With Quote
Old 01-30-2009, 04:33 PM   #2 (permalink)
View davemac2's Photo Gallery
bad wheel bearing?
davemac2 is offline   Reply With Quote
Old 01-30-2009, 05:47 PM   #3 (permalink)
View toyomoho's Photo Gallery
Check condition of trans fluid, should be red or reddish in color not black.
No noise if you let of gas or shift trans into Neutral at hwy speeds?
Old 01-30-2009, 08:23 PM   #4 (permalink)
Thanks for being specific
Changed trans fluid (drained only), put Lucas in., noise happens above 40 and will whine/react to accelerating or decelerating in drive/overdrive only, after changing burnt smelling fluid, it still smells burnt, red in color, doesn't slip at all or leak, mechanics first impression is NOT the torque converter but the gears in trans.
