Busted Oil pump drive pulley - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-31-2009, 09:35 PM   #1 (permalink)
View dredwin's Photo Gallery
So, my kids camry 98 2.2 died. (I figured it needed a new timing belt and water pump since it was leaking coolant through the timing belt cover)
I pulled the upper timing belt cover and noticed oil, coolant, and shrapnel from a broken oil pump pulley. It was the last thing i was expecting to see).
My question...do you think the oil pump is also bad? I'm having trouble removing the Crankshaft pulley so I can't get the belt off...but was wondering what people thought.
dredwin is offline   Reply With Quote
Old 02-09-2009, 12:55 PM   #2 (permalink)
Update
I was wrong. It was the water pump that blew up (ball bearings all through the timing belt cover...even a little hole at the bottom of the cover where I'm sure a piece flew out.
So I replaced the water pump, all the seals/gaskets, belt...now I'm just waiting for the timing cover gasket to come in before I can set the timing.
Old 02-09-2009, 03:30 PM   #3 (permalink)
The Connoisseur
CharmCityES's Avatar
good you figured it out
ive neve seen an issue with an oil pump on any toyota, but theyre sure as hell notorious for having water pump issues
The "Executive Sedan"
