Hey, I gotta 99 Camry V6 throwing codes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-01-2009, 06:28 PM   #1 (permalink)
axhammer's Avatar
View axhammer's Photo Gallery
Canada Hey, I gotta 99 Camry V6 throwing codes
Hi guys and greatings from Toronto, Canada. I got a 1999 Toyota Camry with a P0340 and P0330 and would like some help. I will be posting in the correct section of the forum. Thanks
axhammer is offline   Reply With Quote
Old 02-01-2009, 08:03 PM   #2 (permalink)
View toyomoho's Photo Gallery
P0330 Knock Sensor 2 Bank 2. Bank 2 is closest to the radiator
P0340 Camshaft position sensor
Old 02-02-2009, 10:24 PM   #3 (permalink)
axhammer's Avatar
Hey, thanks but does the V6 have two Camshaft Position Sensors or one? I found the front one, is there a rear one?
Thanks
Old 08-13-2010, 06:19 PM   #4 (permalink)
View belfest's Photo Gallery
I'm having a similar problem. My girlfriend's sister's 1999 Camry's camshaft position senor. I've replaced her sensor and we're still getting the sensor error. I hooked up an Ohm meter to the old and new sensors which resulted in 1107 Ohms for the old and 1137 for the new. When I hooked it up to the connector their are 0 ohms being returned. I checked the Crankshaft sensor at the wiring harness near the alternator and received 0 phms at the sensor and the connector. Could this be an indication that the computer is bad? The car tries to turn over and it has fire but it won't start.
belfest is offline   Reply With Quote
Old 08-13-2010, 09:00 PM   #5 (permalink)
1MZ powered MR2
Jason.MZW20's Avatar
Gameroom cash: $226450
View Jason.MZW20's Photo Gallery
Could be a break in the harness wire or an ECU issue, but I'm leaning toward a wire break. You also can't check resistance with voltage. Check for voltage at the connector terminals.
1991 Toyota MR2 V6
Ported, rebuilt 3.0L 1MZ
Fully OBDII compliant and California smog legal
Jason.MZW20 is offline   Reply With Quote
The Following User Says Thank You to Jason.MZW20 For This Useful Post:
belfest (08-13-2010)
Old 08-13-2010, 09:49 PM   #6 (permalink)
Thanks Jason,
I've checked the wiring harnesses and wires for the camshaft sensor back to the firewall but did not see a break, frayed insulation, stripped wire or anything like that. Is there anyway to test the ECU for voltage leading to the cam or crankshaft sensors? Does anyone have a wiring diagram for the ECU?
