94 Camry No Start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-05-2009, 04:05 PM   #1 (permalink)
View colt45rbc's Photo Gallery
Canada 94 Camry No Start
This problem happens about once a week. I turn the key and nothing...all the dash lights come on etc. Try to start in neutral..nothing. I move the shifter back & forth..try to start, again nothing. After a combination of: taking key in & out, moving the shifter..the car starts like there wasn't a problem. Any ideas...Thanx to all!
292k,2.2L,Auto..north American built
colt45rbc is offline   Reply With Quote
Old 02-07-2009, 12:34 AM   #2 (permalink)
View ITTRay's Photo Gallery
could be the ignition switch, starter solenoid, or just a badly corroded starter wire. I would check all the starter connections first. If you see corrosion make sure you unplug your battery cables or you will shock yourself if you make ground with the hot wire. Clean the connections with some contact cleaner and steel wool. Then check to see if you still have the problem. My guess is that your ignition switch is worn out and working properly when you hold your mouth right.
ITTRay is offline   Reply With Quote
Old 02-07-2009, 12:45 AM   #3 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
Maybe your neutral safety switch? Check and adjust if necessary.
Jimnist is offline   Reply With Quote
Old 02-07-2009, 05:38 AM   #4 (permalink)
Thanx for your input, are you aware of a link describing how to adjust the SN switch????
Old 02-07-2009, 05:41 AM   #5 (permalink)
Thanx for your input, I'll try it..re holding my mouth, this has only happened when parking in front of the post office..so I guess "don't go to the post office" right
Old 02-07-2009, 06:18 AM   #6 (permalink)
'93 LE Wagon, V6
View DFBonnett's Photo Gallery
Some info which might relate.......
http://www.4x4wire.com/toyota/maintenance/starter/
DFBonnett is offline   Reply With Quote
Old 02-07-2009, 07:40 AM   #7 (permalink)
セクシーの定義
Do a search mate, there's bound to be at least one.
Old 02-07-2009, 08:36 AM   #8 (permalink)
Gameroom cash: $303255
To test for defective starter solenoid contacts, try this simple test the next time it doesn't start. Have someone else hold the key in the start position, while you go under the hood and tap the starter's solenoid with a wrench or small hammer. If the starter now turns, you have identified the worn starter solenoid contacts problem. Then do a search for "starter contacts" on this forum for it's causes and cures.
Mike
