Go to autozone, advance, orielly's, or your local parts store. Ask them for a new cap. They are inexpensive and easy to install. If you have a crack in the one you have now than you should replace it anyways. If this fixes your problem then....wala!!presto!!bingo!!You Got it Dude!!!
If this doesn't fix your spark problem then replace your coil.
How do you know you aren't getting spark? You MUST ground the threads of the spark plug to the block or other grounded source in the engine bay, then have someone try to start the car. If you dont have spark after trying this, then you have a bad cap, coil, or plug wires. When you get the new cap, make sure you get the rotor button that spins inside the cap. That should be all, really...
