Toyota Camry 96 SRS/ABS Warning Light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-11-2004, 03:28 PM   #1 (permalink)
View HandedMyOwnLife's Photo Gallery
Question Toyota Camry 96 SRS/ABS Warning Light
Hey guys, I have a 96 Camry LE V6 and the ABS/SRS warning light poped up after I replaced the CV HalfShalf. I don't know what I've done wrong can you guys give me some inputs. It was my first time doing the axle so, not sure what steps I've need to go through. One curious Idea occured after the light came on is that I did not disconnect the battery, I don't know if that would caused the problem. Also, when I take the axle out again and turned on the ignition key, the Warning light is off, and the horn work( Horn does not work when the CV HalfShalf is installed).
Please give me some advice on what I should do to fix the problem. I don't know If I've messesd up any of the sensors, If I did, which sensor could I have possibly messed up?
Thank You,
PL
PL
HandedMyOwnLife is offline   Reply With Quote
Old 01-12-2004, 12:18 AM   #2 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
hmm...no idea.
TN Map - Add Yourself
Phi is offline   Reply With Quote
Old 01-12-2004, 04:30 AM   #3 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
i have no clue how an axle can be causing all this crap
at least get someone to diagnose what the light came on for
-Nick
Nick is offline   Reply With Quote
