IAC valve location 95 camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-06-2009, 11:25 AM   #1 (permalink)
View DPop's Photo Gallery
I need to know where the IAC valve is located on my 95 4 cyl 2.2 camry. Thank you
DPop is offline   Reply With Quote
Old 02-06-2009, 01:18 PM   #2 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
I think it's mounted on the throttle body, either underneath or behind.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 02-06-2009, 02:43 PM   #3 (permalink)
Gameroom cash: $303255
It's underneath.
Mike
Old 02-07-2009, 01:02 PM   #4 (permalink)
View White95Cam's Photo Gallery
I found it easier to remove the IAC if you remove the TB. The phillips screws can be a bitch to get out. I was luck enough to get three out but the head on the fourth one stripped. I was able to wiggle the IAC and use vicegrips to remove the last screw. I replaced the screws with allen head ones so I won't have any problem in the future.
W95C
White95Cam is offline   Reply With Quote
