Lowest Drop for Gen 4-4.5 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-06-2009, 01:10 PM   #1 (permalink)
Togue superstar
t3chnique's Avatar
iTrader Score: 6 reviews
View t3chnique's Photo Gallery
4th Generation Lowest Drop for Gen 4-4.5
What is the lowest possible drop for a 99-01 Camry? I have a I-4 if that helps.
I've read through the suspension FAQ and it says Sprints are the lowest. And you can get them for $99. I've checked eBay and Sprints are no where to be found for the Gen 4.
At this point, the only springs I've found are the Tenzos.
Im looking for something at least 1.8 in" in the front and rear. Lower would be nice though.....
Just suspension and cosmedics.
t3chnique is offline   Reply With Quote
Old 02-06-2009, 04:26 PM   #2 (permalink)
View y0t4's Photo Gallery
http://cgi.ebay.com/ebaymotors/ZENN-...Q5fAccessories
says here you have 2 min!! gooooo lol but im sure there will be more
y0t4 is offline   Reply With Quote
Old 02-06-2009, 04:28 PM   #3 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
If you're going to lower a Camry, you might as well save your money and just cut the springs.
Just make sure it's even though!
Chris Crash is online now   Reply With Quote
Old 02-06-2009, 05:10 PM   #4 (permalink)
Togue superstar
t3chnique's Avatar
ohhh man. Thats cheaper than Tenzo and Sprint.
It even says the car won't sag
Man the description is so convincing.....
Old 02-06-2009, 05:15 PM   #5 (permalink)
Togue superstar
t3chnique's Avatar
nahh no way I'm doing that. No matter how even you think you cut them, it will never be dropped evenly doing that way.
I'm going to need the OEM springs just in case I ever sell the car.
Old 02-06-2009, 05:18 PM   #6 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
coilovers. thats the lowest drop. other then that tenzo springs.
and completely ignore what chris crash suggested. im assuming hes just being sarcastic.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 02-06-2009, 06:12 PM   #7 (permalink)
'_'
Touge Star
'_''s Avatar
Gameroom cash: $421512
View '_''s Photo Gallery
If you have the money, go for the Tein CO's. Good ride quality and you can slam it down if you want. I would get Tein's but I'm not allowed to spend any more on the car..
山道だいすきです。
http://www.cardomain.com/ride/2538603
'_' is offline   Reply With Quote
Old 02-06-2009, 09:28 PM   #8 (permalink)
Togue superstar
t3chnique's Avatar
No worries, i know the dangers of cutting springs.
at this point, spending around 1.5k on coilovers alone is outta the question. Im a student and have no job at the moment. I think Im going to buy the springs in the eBay link above.
Old 02-06-2009, 10:39 PM   #9 (permalink)
I HAS BOOST!!!
bigbird's Avatar
it would be wise to buy a good set of performance shocks too.
R.I.P.
Car Domain:
Old 02-07-2009, 12:54 AM   #10 (permalink)
Togue superstar
t3chnique's Avatar
yeah? My OEM ones are almost new because I just got em replaced not too long ago...
What will "performance shocks" do for the ride (stiffer)?
Old 02-07-2009, 06:51 AM   #11 (permalink)
I HAS BOOST!!!
bigbird's Avatar
thoes springs your about to buy arent the best quality. rolling on springs that low and likely fairly soft on OEM shocks will not only ware out the shocks but the springs as well. this happened to me with my sprints long ago. same drop and considered the same quality. i drove for way to long on OEM shocks and my ride wasnt great....just became worse and worse. i got the drop i wanted but i was bottoming out alot and would float alot. performance shocks, either KYB(slighter stiffer then OEM) or tokico(stiff) will prolong the life of the shock and spring as well as make the car rider better...less bound and rebound.
R.I.P.
Car Domain:
Old 02-07-2009, 03:41 PM   #12 (permalink)
Togue superstar
t3chnique's Avatar
alrite. Thanks a LOT dude.
One last thing, if I bought TEIN springs which cost much more, would I still have to get new shocks or would the OEMs be sufficient?
Old 02-07-2009, 03:55 PM   #13 (permalink)
'_'
Touge Star
'_''s Avatar
You should get aftermarket struts (KYB/Tokico/etc) with any lowering springs you install.
山道だいすきです。
Old 02-07-2009, 05:02 PM   #14 (permalink)
I HAS BOOST!!!
bigbird's Avatar
personally id advise getting it all together, it makes install MUCH easier, even if the teins would be ok for a while without. getting thoes tenzos is fine as long as ya have some good shocks to go with them.
R.I.P.
Car Domain:
Old 02-07-2009, 11:29 PM   #15 (permalink)
Togue superstar
t3chnique's Avatar
alrighty then.
thanks for the advice everyone
