tie end rods - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-06-2009, 10:33 PM   #1 (permalink)
FrankieCarbone's Avatar
View FrankieCarbone's Photo Gallery
tie end rods
i also have a 1991 mr2, and i remember once a few years back my carwould make a cackling sound whenever going over a small bump or pot holes, kind of liek something was loose, it was the tie end rods, im getting the very same sound now in my 1994 camry, do i need to change all 4 tie end rods (?) or just the fronts? i belive i get the sound all around
FrankieCarbone is offline   Reply With Quote
Old 02-07-2009, 12:19 AM   #2 (permalink)
View toyomoho's Photo Gallery
Do you mean sway bar end link?
Can also be sway bar bushings or upper strut mounts. Any squeaking when going over speed bumps, rattling when going over pot holes?
Old 02-07-2009, 09:26 AM   #3 (permalink)
O-Dark-30
frenum49's Avatar
View frenum49's Photo Gallery
hmm
Tie-rod ends are only on the front tires. They are the links that steer the front tires. There are inner and outer tie rod ends but it is more common for the outer end links to fail rather than the inner. (except on some Chrysler vehicles). You can tell if yours are bad by jacking up the front of the car until the wheels are off the ground. Grabbing the tire at 9 and 3 o'clock positions and wobbling the tire in and out. If there is play you will be able to feel it and see it at the outer end link. There are a few different reasons why your car would make clunking sounds over bumps. If you don't trust your knowledge on this I would take the car to a garage and have them take a look.
frenum49 is offline   Reply With Quote
Old 02-09-2009, 01:14 PM   #4 (permalink)
its not a squeaking sound at all, its rattling sound whenever i go over bumps or just basically anything other than a perfectly smooth road
