Shift Solenoid E Malfunction (Shift Solenoid Valve SL) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-08-2009, 03:08 PM   #1 (permalink)
Gameroom cash: $162600
View blackcloud's Photo Gallery
i have code P0770 Shift Solenoid E Malfunction
(Shift Solenoid Valve SL) where is this solenoid located
manual shows next to the Park/Neutral Position Switch (just behind it)
1997 2.2 what I'm asking do i remove the pan.
is it toward the front of car in the valve body?
SYSTEM DESCRIPTION
The ECM uses the signals from the Throttle position sensor,
Air–flow meter and Crankshaft position sensor to monitor the
engagement condition of the lock–up clutch.
Then the ECM compares the engagement condition of the
lock–up clutch with the lock–up schedule in the ECM memory
to detect mechanical trouble of the shift solenoid valve SL,
valve body, torque converter clutch or automatic transaxle
PREPARATION:
(a) Remove the oil pan.
(b) Remove the shift solenoid valve SL.
CHECK:
(a) By applying 490 kPa (5 kgf/cm2, 71 psi) of compressed
air, check that the solenoid valve does not leak air.
(b) When battery positive voltage is supplied to the shift solenoid
valve, check that the solenoid valve opens
i only see the 2 shift solenoid valve No.1 or No.2.
i have read all thread some say inside the pan some say outside the pan
i install a jdm ENGINE and AUTOMATIC TRANSAXLE did not get this code before no did not drop pan but did change oil.
going to drop pan after 500 miles. oil look very good that's why i did not drop pan
my idel speed 650 rpm
Idle speed : 750 ± 50 rpm
shift good and goes into overdrive
thanks to all
been a member for sometime
blackcloud is offline   Reply With Quote
Old 02-08-2009, 07:00 PM   #2 (permalink)
i found my answer
SHIFT SOLENOID VALVE SL
ON–VEHICLE REPAIR
1. REMOVE PARK/NEUTRAL POSITION SWITCH
2. DISCONNECT SHIFT SOLENOID VALVE SL CONNECTOR
3. REMOVE SHIFT SOLENOID VALVE SL
(a) Remove the 2 bolts and shift solenoid valve SL.
(b) Remove the 2 O–rings from the shift solenoid valve SL.
4. INSTALL SHIFT SOLENOID VALVE SL
(a) Coat 2 new O–rings with ATF and install them to the shift
solenoid valve SL.
(b) Install the shift solenoid valve SL and 2 bolts.
5. CONNECT SHIFT SOLENOID VALVE SL CONNECTOR
6. INSTALL PARK/NEUTRAL POSITION SWITCH
I will remove it and test it
thanks
