Need help on DRUMS for a 1997 CAMRY - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-10-2009, 05:45 PM   #1 (permalink)
View FishyMan's Photo Gallery
I was wondering if changing out the drums for the camry to be difficult? More so, how much would the drum set cost? I plan on grabbing some OEM DRUMS set and having them changed out.
Car has about 70K on it? Front brake pads/rotors were done, but would like the rear to be changed out.
Any ideas?
FishyMan is offline   Reply With Quote
Old 02-10-2009, 08:21 PM   #2 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
changing out drums and brake shoes are easy. the drum just slides off, and the shoes are held in place by 3 springs and the parking brake cable. if i recall correctly, each drum from napa was about $40-50 and the set of shoes was about $40.
rear drum brakes wear much slower than front disks, so dont assume they need to be changed because the fronts are worn. take a look before you buy the parts.
Old 02-10-2009, 10:26 PM   #3 (permalink)
I plan on just having it done 2 the shop type of thing. My sister is complaining about some noise in the back.
Old 02-11-2009, 06:33 PM   #4 (permalink)
4th Gen Camry Owner
View kpszar's Photo Gallery
A Toyota Dealership in Ny wanted $150 for one drum! I would recommend going NAPA but it turns like a rust orange.
kpszar is offline   Reply With Quote
Old 02-12-2009, 11:39 AM   #5 (permalink)
ghettosled's Avatar
what kind of noise? like a metal on metal noise? if so, it might just be from the dust shield scraping the drum. mine use to do that as the weather warmed up and as the (OEM) drums drums started to rust more and more.
Old 02-12-2009, 07:02 PM   #6 (permalink)
That's why I am wanting to get it fixed.
When I order, do I just tell them DRUM SET?
I just wanna be knowledgable before heading to the dealer. It sounds like there's some squeek, but the front were done and w/ OEM pads. So I am worried a tad. The ebrake could need an adjustment too.
Thanks
Old 02-12-2009, 10:13 PM   #7 (permalink)
ghettosled's Avatar
tell them you want to order brake drums and shoes for the car (brake pads are used on disc brakes, brake shoes are used on drum brakes). anytime drum brakes are replaced, the parking brake will have to be adjusted as they pull the shoes to brake the wheel. as an added FYI - the camry drum brakes are considered "self adjusting" because using the parking brake actually adjusts the rear brakes automatically. last time i replaced my shoes and drums, i didnt pre-adjust the brakes because i was curious to see how many times i had to pull the parking brake handle to finish adjusting (until there is resistance). i needed to pull the lever about 20 times.
Old 02-12-2009, 10:33 PM   #8 (permalink)
just a nobody
Doubt very much you will need new drums at 70k, have you actually have them off and measure them? Brake dust inside the drum can sometimes cause scrapping type noise especially noticeable at low speed.
N.E.O.
Old 02-13-2009, 02:22 PM   #9 (permalink)
DIY : I believe
Maim Menu's Avatar
View Maim Menu's Photo Gallery
Flat black Barbecue paint =
Restoring '65 Chevy Impala Super Sport w/ 327-300 small block, Edelbrock carb/intake and T-5 tranny that will probably blow up.
Black '98 Camry LE 4Cyl Auto, 188 000Kms and counting
Black '98 Camry CE 4Cyl Auto, 295 000Kms and counting - SOLD
Maim Menu is offline   Reply With Quote
