GEN 3: 93 Camry: power button next gear shifter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-11-2009, 10:15 PM   #1 (permalink)
View Sandy_H's Photo Gallery
Hi, I have 93 Toyota Camry,it has a small button on the same panel the shifter is located. It has ECT / PWR written on it. When I press it to power mode it accelerates faster. Off late I pressed so heavily that it demounted from the small hole, it went down and I cant change the mode now. Any idea how bigger thing that to repair? do I need to remove the whole gear panel? any idea how much that would cost me if I go to mechanic.
thanks,
sandy.
Sandy_H is offline   Reply With Quote
Old 02-11-2009, 11:07 PM   #2 (permalink)
View toyomoho's Photo Gallery
The oval center panel around the shifter lever pulls out. You may be able to access the plug with this section removed.
If not the center console can be removed. There are two screws in the glove box and one on each side of the rear of the console. Once the screws are out pull up and back.
Old 02-11-2009, 11:31 PM   #3 (permalink)
Oh thats a great information, will try that. thanks.
