Foam behind air dash vents - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-12-2009, 10:54 PM   #1 (permalink)
OREGONian
ToRn's Avatar
View ToRn's Photo Gallery
3rd Generation Foam behind air dash vents
Notice when i turned the air on today there are a few loose square charcoal colored foam pieces in the vents and am wondering why its there, is it the filter for the air? if so where can i locate it?
Seating 5 Getting dunked.
Vid of my sloWmry----> http://www.youtube.com/watch?v=voIgDCq7HaA
ToRn is offline   Reply With Quote
Old 02-12-2009, 11:44 PM   #2 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
There are foam insulators around the vents and also on the ducts below the steering wheel. Recently had mine apart to remove debris from the blower motor and ducts (damn mice ). The foam is just worn out and falling apart. Nothing major. Just pull it out with a pair of tweezers and forget about it.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
Old 02-12-2009, 11:48 PM   #3 (permalink)
OREGONian
ToRn's Avatar
Not replacing it wouldn't hurt it later? also again about the air is there really no air filter between the outside air going in the car?
Old 02-12-2009, 11:52 PM   #4 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
the gen3/3.5 did not have a cabin air filter.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 02-13-2009, 12:03 AM   #5 (permalink)
Certifiably Insane
96paseo's Avatar
Its not going to hurt anything. You will still get good airflow. Its also a good idea to check your blower for any debris. The foam you mentioned could have been brought in by mice. My blower had a horrible vibration until I cleaned it out.
Old 02-13-2009, 12:32 AM   #6 (permalink)
OREGONian
ToRn's Avatar
where is/ how do i get to the blower? kinda makes a sound like it needs lubing.
Old 02-13-2009, 12:43 AM   #7 (permalink)
Certifiably Insane
96paseo's Avatar
Passenger side under the glove box. Un-snap the plastic guard. There are 3 bolts that hold the blower onto the housing. 8mm or 10mm I forget which size. Remove the power plug and remove the bolts. It will just drop right out.
Old 02-13-2009, 12:46 AM   #8 (permalink)
OREGONian
ToRn's Avatar
ALright, thanks for the help guys
