Has anyone put gen3 camry struts on a gen4 camry or gen1 solara, or vice versa (g4cam/g1sol struts on g3 cam)? I ask because it seems from reading around on here that the springs are pretty much interchangeable, and I even remember seeing a thread where someone recommended "gen3/4 k-sports" for someone's gen1 solara, so it seems like it might be possible.
here's why i ask - koni yellows are apparently available for gen3:
http://www.modacar.com/products/Toyota/Camry/MODASHS/ but not available for gen4.
I'd like adjustable damping for the camry but i don't want a full on coilover setup (k-sport/d2) due to cost, plus progressive rate springs are your friend on the streets around here.
I'm not real worried about things like abs sensor wires or even brake hose attachment points - I can always attach those in other ways. i also know that the trd rsb fits on a gen3 with no mods, so that tells me the sway bar attachment points are close enough - at least in the rear.
If nobody knows for sure, then does anyone have a set of stock gen3 struts they would give to me so i can take measurements and/or do test fits on my gen4? Preferably you'd be in Houston, TX area so there's no shipping.
search terms/keywords for future searches, since i wasn't able to find this info by searching: retrofit retro cross over interchange swap x-over generation 3 fit put generation 4 strut shock absorber suspension susp spindle knuckle hub mount bolt pattern does it fit
