01 Camry 5SFE Steering - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-13-2009, 06:40 PM   #1 (permalink)
projectSXV20's Avatar
View projectSXV20's Photo Gallery
I did a search and got some ideas as to what's wrong, but the symptoms I'm having are a little different.
My power steering occasionally locks up while driving. It would let me turn the wheel once then lock up, and I would gently keep moving it in that direction to make it turn all the way. This happened twice to me today on the road which made it very difficult to get home.
Conditions: Very heavy rain, and lots of dips full of water. Th car has been modified with Tein springs, and Tokico shocks. Everything else is stock.
I've checked the power steering fluid and it's right where it should be. When I got home I turned the wheel all the way from the left to the right and back with no problems. I've observed the steering locks up when going through a deep puddle.
Any ideas will be helpful, thanks.
projectSXV20 is offline   Reply With Quote
Old 02-13-2009, 06:53 PM   #2 (permalink)
View toyomoho's Photo Gallery
Locks up or the PS stops working but you can still steer?
Check the PS belt.
Old 02-14-2009, 01:23 PM   #3 (permalink)
The belts were fine. Apparently some water got into the steering system (idk which part). Gently moving the wheel little by little took care of the problem. Now I will be avoiding deep water as much as possible, but it's good to know what to do when stuff like that happens.
