Alternator??? - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-16-2009, 06:35 PM   #16 (permalink)
View sr5punk's Photo Gallery
it possibly could. I have recently screwed in a spark plug that was almost unscrewed in my gen 4 i4 camry. had the valve covers replaced and the shop that did it didnt screw the plug in all of the way. so i was getting a check engine light and a nasty idle. had the code cleared at auto class, cleaned all the plug leads and screwed her in. works famously now. altyhough on my old gen 3, i left 1 plug wire out and drove the car in revers. this killed the coil. so i replaced the coil, plugs, wires, dizzy cap and rotor just for good measure. it wouldnt hurt especially on a 10-15 year old car.
sr5punk is offline   Reply With Quote
Old 02-16-2009, 11:28 PM   #17 (permalink)
View Poser's Photo Gallery
Ok, if a mod stumbles upon this thread... I would greatly appreciate changing the title to: Crank, No start condition.
To wit this is what I have done:
1. Replaced the alternator with a bench tested reman'd alternator
2. Replaced the battery
3. Checked all fuses, fusible links and relays
4. Checked the fuel pump upon turning key (to see if perhaps the pump had gone and was starving the engine)
5. Changed plugs and plug wires. (Did find that one of gaskets needs to be replaced, as there was oil on the plug in the first cyclinder, but has clear evidence of carbon deposits from firing)
6. Checked the PCM for signs of visible electrical damage (charring, discoloration). I know this no substitute for getting it scanned... but I felt I needed to at least look
I have narrowed it down to these possible problem areas...but am by no means experienced enough, and would love some second opinions/suggestions:
1. Crankshaft / Camshaft position sensors
2. Ignition Coils
3. Igniter
4. PCM (I really hope not)
My primary concern is that since the alternator was bad, it may have spiked back and damaged some of the more sensitive electrical components. I am stuck. Any ideas would be awesome. Thanks to everyone who has responded thus far... it has kept my resolve up.
But I may have to break down, have it towed in and diag'd.
Poser is offline   Reply With Quote
Old 02-17-2009, 08:12 AM   #18 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Did you / were you able to check for spark at the plugs??
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 02-17-2009, 01:31 PM   #19 (permalink)
I have not checked for a spark. However, I guess that would be a good way to eliminate the coils.
What is the safest method for doing this?
