My wife started her gen4 4cyl camry this morning, no problem. She got about a half a block before she said the dash lights all flickered on and she lost engine power. There is power to all of the accessories (radio, lamps, dash indicators etc...) and it when you turn the key it sounds like the starter is engaging but the engine wont kick over.
It feels like an alternator issue, so I am going to take it to an autozone and get it bench tested. But I was wondering if you guys have some other thoughts as to what it could be...since I am stuck at work until 3 and wont be able to do anything until then,
Terminals and connections are all clean, tight and non-corroded. I replaced the bat cables about a month ago.
EDIT: and thanks for the feedback guys.
EDIT2: Any suggestions on best place to purchase the brush inside of generator. I am going to take apart the housing and see if the brush is excessively worn. Also, how is it that the voltage regulator is only 1$ cheaper for a reman'd alternator?
The replacement parts kit is sold with high mark up because not many people, including garage mechanics want to spend the time to do the work.
Re-manufacturing factory buys the 'cores' and replacement parts like new regulators, bearings, brushes, etc. in bulk and use specialized tools to make the job much faster, and cheaper than you can as a DIY.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
IMHO you are better off looking an auto electrical rebuilder in your area (check the yellow pages) and taking your alternator to that shop for a rebuild; especially if it is the original Denso alternator that the car came with. In my experience, these people tend to do a better job than the bulk rebuilders and usually charge about the same price.
Mike
Not the original, but I get ya. Alternator was bad, bought the reman'd...popped it in (after a bench test at Advance) and still getting the same problem. All electrical responds, lamps radio and dash... engine spins, the alt but no start. Thoughts???
EDIT: Replaced Battery with Fresh Battery... still no go. Could it be a bad igniter?
"would that prevent the engine from turning over?"
These 2 terms generally mean the same thing. They both mean the act of the starter spinning over the engine. It can also be called cranking. Is the starter turning (spinning over the engine) or not?
chances are the battery is drained from the alternator going out. replace that and look into replacing the wires and cap. after that, and it still doesnt move, then I would say start looking at major items.
Mike
Sorry. Yes the car is cranking. You can also see the drivebelt moving as well. I am going to check all fuses again. I can imagine one or two plug wires being bad, but all four going at the same time seems far fetched. Could one bad wire prevent the engine from starting?
