Hi all,
I'm getting a check engine light code of 25, meaing overly lean. The plugs look like this:
Could the plugs in the bottom row look lean? They are pretty white. The other bank (top row) looks to have two slightly rich plugs and one normal.
Car runs great, compression is 180 all around, fuel pressure vsv valves seem to check out fine. Not sure about the O2 sensors though. The lean bank seems to have a bad sensor, per our tests but a bad sensor using will make that bank run rich, right? A bit confused here.
Any ideas?
Thanks.
