The blower motor I don;t think has a fuse. When it stops working, it's usually the Blower Motor relay, resisitor.....I;m fuckign brain dead and forgot what it is called. Someone else will correct me before long.
As for the fuses, there is a bunch behind the change tray (Bottom left of steering wheel). There are spots in the under hood fuse panel that are not used, so won't have fuses or relays.
As for the radiator fan, the 1993 Camry has a Hydrolic fan, so it ALWAYS spins a little. If you mean it spins at full speed, all the time, thats an issue. If it;s just a slow spin, like you can stop it with your hand without really getting hurt, thats normal.
