3rd Gen... what is normal temp??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-16-2009, 08:54 AM   #1 (permalink)
View toyo22r's Photo Gallery
I just picked up a new (to me) 95 wagon 5SFE. I am wondering what the temp gauge needle should read normally. This one sits about a needle's width ABOVE the half way mark. Stays there solid. I even unplugged the cooling fan temp sensor so that both fans stay on to see if that would bring the temp down. No change. It runs fine but just curious where the needle should point.
Thanks
toyo22r is offline   Reply With Quote
Old 02-16-2009, 01:57 PM   #2 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Should be right about in the middle, and not change.
5 Lug Corolla WHAT?
Old 02-16-2009, 02:21 PM   #3 (permalink)
View camryvibe's Photo Gallery
Our's is just a bit above the middle of the range. The ScanGauge reads the temperature as in the high 180's F when warmed up.
camryvibe is offline   Reply With Quote
Old 02-16-2009, 02:26 PM   #4 (permalink)
Well sounds to me like that is normal then. I used an IR thermometer and surface temp of the upper radiator hose was ~180 while the metal "neck" that the hose attaches to on the engine was closer to 200.
I was just a little concerned as my 2nd gen Camry is slightly below half way mark.
Old 02-16-2009, 02:59 PM   #5 (permalink)
View frojoe's Photo Gallery
As long as its near the middle I'm willing to bet that the fact that it doesn't change is more important. I think your fine.
frojoe is offline   Reply With Quote
Old 02-16-2009, 06:53 PM   #6 (permalink)
all my heros are evil
cykaaro's Avatar
View cykaaro's Photo Gallery
Interesting. Mine since I got it always sits about 1/4" down from the half mark and doesn't move. Doesn't matter what time of year it is either.
cykaaro is offline   Reply With Quote
Old 02-16-2009, 09:37 PM   #7 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
Probably has something to do with your sending unit not being as accurate as it should be. Mine is always a needle-width below halfway.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
