not starting when cold !! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-17-2009, 07:04 AM   #1 (permalink)
View 92classic's Photo Gallery
hello everybody, i am new to this forum, i hope somebody can help with this, i have a 92 camry 4 cyl. 2.2, automatic. 173,000k , recently car is not starting in the mornings, it cranks, but i have to crank it like 6 or 8 times before it comes to life, battery is good, starter sounds healthy doing it's job, after it starts is fine the rest of the day. any advice?? i read about coolant temperature sensor, ignition coil, IAC, etc,etc, but i am not sure at this point where to start, anyway thanks for your help.
92classic is offline   Reply With Quote
Old 02-17-2009, 09:54 AM   #2 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
Cleaning your TB is the place to start. If that doesn't work, check the IAC motor and ECT. At that mileage and age, you should also check your vacuum lines for dry rotting.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
Old 02-17-2009, 10:05 AM   #3 (permalink)
thanks paseo, a question, the ECT is the same as coolant temperature sensor? excuse my ignorance.
Old 02-17-2009, 11:27 AM   #4 (permalink)
Certifiably Insane
96paseo's Avatar
Yes, that is correct.
Old 02-17-2009, 10:30 PM   #5 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
View JCamry94's Photo Gallery
3rd Generation
Same stuff happened to me, seafoam that bitch! (the TB)
ACCIDENT...
Help me bring 'er back to life!!!
BUY MY STUFF: http://www.toyotanation.com/forum/66...e-all-obo.html
Thanks
JCamry94 is offline   Reply With Quote
Old 02-17-2009, 11:35 PM   #6 (permalink)
just a nobody
What have you done so far to diagnose the problem?
N.E.O.
Old 02-18-2009, 08:01 AM   #7 (permalink)
i changed the ECT, cleaned the TB, the IAC, adjusted the timing with a timing light, was running good, but like i said the problem was in the mornings, so i wait until this morning and..... now the car won't start, before it just to start after the 6 or 8 crankings , now, it's just plain dead, i did a quick check on the sparks, (you know the kind you take the spark plug wire off and hold it against ground) and i saw arcs of sparks but the were intermitent, you know like, i crank it and see it, and the crank it again, and don't. at this point i want to believe it's the ignition coil, but i believe those when they go bad they just plain die. in my case i still have spark. well, next i don't know, maybe fuel pump, or maybe wires. heck i don't know.
Old 02-18-2009, 01:03 PM   #8 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Problem in morning may be due to overnight condensation. Ignition wires or cracked distributor may be the cause. Spark needs to be bright and blue, not just white. It should also not be intermitant on each firing. The ECT could have been checked to see if out of spec. before just replacing.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 02-18-2009, 02:33 PM   #9 (permalink)
thanks stillrunning, your answer makes a lot of sense, i found another post from somebody having the same problem, well similar, and he fixed by changing the coil, i think i am going to change the spark wires and the ignition coil to see if that fix the problem, yeah , you are right i should have check the ECT before replacing it. i am 30 dollars poorer now.
Old 02-18-2009, 11:36 PM   #10 (permalink)
just a nobody
Check the resistance of the ignition coil and pickup coils, weak spark can cause starting problem. Check the spark plugs and plug wires too.
N.E.O.
Old 02-19-2009, 05:53 AM   #11 (permalink)
an update on this, i changed the coil and put new bosch spark wires and this morning the car sarted with no problems, i hope it keep it that way, i have a serious debate in my brain, as to know why the coil went bad like that, i remember a year ago replacing the same coil, but the symptoms were not starting at all, and no sparks whatsoever, this time i had sparks and once the car started was fine the rest of the day, this coil fail very often?? like i said i replaced a year ago with an advance autoparts one, a year seams to me like a very short period of time for a coil to go bad, but once again is me. thanks everybody for your help. i keep you updated .
Old 02-19-2009, 05:58 AM   #12 (permalink)
Why would you assume bad coil when you also replaced wires? Did you test coil before replacing it? Why did you not replace wires first to see if that solved problem?
Old 02-19-2009, 07:52 AM   #13 (permalink)
stillrunning, when i changed the coil and fired it up, i still have the old wires, but just in case i replaced them, because the old ones were 5 years old. i got this car 6 years ago.
Old 02-19-2009, 12:10 PM   #14 (permalink)
Turbo S2000 FTMFW
ECale3's Avatar
iTrader Score: 10 reviews
View ECale3's Photo Gallery
Sounds like she has hypothermia, you should get her a blanket.
The worst part of dying is being alive.
ECale3 is offline   Reply With Quote
