Both fans on when engine is cranked up in the morning
Hi I just noticed the other morning when I started the ignition and both fans started to spin even when the engine is cold - isnt it supposed to be no fans when cold - first fan will start spinning when it has reached optimal temperature, then both fans spin when the aircon is selected?
Is this a relay or switch problem - I thought it was an open thermostat in the past because my engine temp needle never goes up to the middle of the temp gauge - more like just above the bottom line
