Safest Technique: Checking for Spark? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-18-2009, 08:42 AM   #1 (permalink)
View Poser's Photo Gallery
I need to check for a spark in each cylinder to ensure that my ignition coils aren't fried. What is the safest method for doing so on a gen4 4cyl ???
Thanks
~poser
Poser is offline   Reply With Quote
Old 02-18-2009, 11:08 AM   #2 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Disable Fuel Injection, pull EFI fuse (small fuse) in engine compartment fuse box, behind battery along fender.
Fuel pump will not work as well.
You can use a spark gap tester (simple alligator clip with a adjusting screw to change gap and an end to plug your spark plug wire)
OR
Take spark plug wire off one cylinder. put it onto a good spark plug tha tyou know works (note you do not need to remove any of the existing 4 spark plugs) tie wire or zip tie the test spark plug to the engine lift hook with firing tip facing up to ground it so that the threaded section of spark plug touches that hook.
when you reach in the car to start it with the key, you should be able to lean over and see it spark. Or have someone crank it for you.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 02-18-2009, 04:12 PM   #3 (permalink)
Thanks Haj,
Took your advice, got a gap tester for $4 and tested all four plug wires... they fire. All four plugs are relatively new, gapped correctly and in damned good shape.
Back to the drawing board.
EDIT: Just a side note - I pulled the EFI fuse, and could not get a spark. I figured what the hey, if I blow up...its insurance money for the woman...plugged it back in and got a spark.
Old 02-19-2009, 12:17 PM   #4 (permalink)
Turbo S2000 FTMFW
ECale3's Avatar
iTrader Score: 10 reviews
View ECale3's Photo Gallery
Hmm...I woulda suggested you lick your finger, touch the diode, and crank the motor.
The worst part of dying is being alive.
ECale3 is offline   Reply With Quote
Old 02-19-2009, 03:31 PM   #5 (permalink)
My my, how clever... did you come up with that all on your own, or did you employ help?
Ohhh wait, let me guess... you got help from my _________ (insert girl, or whatever real witty noun you wish to use).
Old 02-19-2009, 04:36 PM   #6 (permalink)
Toy_Dreamer's Avatar
View Toy_Dreamer's Photo Gallery
18th century Webster's dictionary
1998 Camry XLE | Black | Custom Halo Lights | Fogs | Infinity Kappa front speakers | Infinity Reference Sub | SRI Secret Weapon R...
Toy_Dreamer is offline   Reply With Quote
Old 02-19-2009, 08:08 PM   #7 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
Didn't know spark plugs had diodes. Ah well, learn something new everyday.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
