94 camry coupe issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-18-2009, 10:57 PM   #1 (permalink)
View cubanboynumba1's Photo Gallery
just registered to the site... i recently bought a 94 coupe ill be posting pictures soon but just wanted to know what is the problem because my car doesn't lock it locks from the inside but not from the outside and if i lock it from the inside and try to unlock it wont unlock neither
cubanboynumba1 is offline   Reply With Quote
Old 02-19-2009, 12:15 AM   #2 (permalink)
just a nobody
Linkage clip to the lock cylinder may have been broken. You will need to take a look to verify, probably will have to remove the door panel to do that.
N.E.O.
Old 03-01-2009, 04:20 PM   #3 (permalink)
i had an alarm installed and works fine didnt want to go to threw too much to fix that right now but the alarm works fine thanks for the info though...
another question my passenger window wont go down or up is that easy to fix?
Old 03-01-2009, 05:43 PM   #4 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
from what ive herd from another member...depending on the problem it can be costly. anotehr coupe guy had to buy a motor secific to the coupe and it cost a bundle. fuzzy on teh details there though. does the window make any noise when you try to put it up or down?
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 03-02-2009, 09:24 AM   #5 (permalink)
just a nobody
Check for both power and ground at the window motor, that will help you determine which direction you will have to go. It could be wiring, switch or motor; however, without some testing, it will be hard to tell.
N.E.O.
Old 03-02-2009, 12:55 PM   #6 (permalink)
i took off the passenger door pannel and found that the wiring wasnt connected so when i connected it and tried to see if the window worked it just makes the noise as if it was to work when you put your window up or down
Old 03-02-2009, 01:18 PM   #7 (permalink)
just a nobody
Sounds like it just need a regulator then; it will be a lot cheaper without the motor, even if you get one from the dealer.
N.E.O.
