What 93k does to suspensions :( - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-18-2009, 11:19 PM   #1 (permalink)
View Manny1337's Photo Gallery
Okay well as i stated my 98 camry has 93k and you are starting to feel it. Im not sure what is really going on it im not too familiar with suspensions but i know its alot rougher when going over bumps than it should be its starting to sound like an 80s chevy pickup truck . i was wondering what usually goes and what needs replacing after 93k of wear and tear.
Manny1337 is offline   Reply With Quote
Old 02-18-2009, 11:45 PM   #2 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Struts and mounts on all 4 corners.
5 Lug Corolla WHAT?
Old 02-19-2009, 06:34 AM   #3 (permalink)
that would fix the bouncing the car 3 times trick. becuase you can push down on that thing and have it come back up all day long lol. how much does parts + install usually run?
Old 02-19-2009, 06:39 AM   #4 (permalink)
also ive noticed sometimes not all the time that when going over a speed bump it sounds like the front springs are squeaking but it happens randomly and not too often
Old 02-19-2009, 05:50 PM   #5 (permalink)
TOYODA KAMURI
the_professional's Avatar
View the_professional's Photo Gallery
keep it to one post at a time, keeps it clean.
There is no small way to fix this. Your struts are definatly done. Just listen to ASG, just fix all 4 corners, just dont forget to replace the mounts too.
You'll be happier and it will be more cost effective if you replace all four at one time.
i love my 1992 Toyota Camry LE 2.2L 5S-FE - 73K
9005 NIGHT GUIDE LOW BEAMS|FOG LAMPS|PIONEER HU&AUDIO|KEYLESS ENTRY
1995 Acura Legend LS KA7 3.2L C32A - 87K
SADLY, SHE HAS MUCH MORE MODS...
the_professional is offline   Reply With Quote
Old 02-20-2009, 11:13 AM   #6 (permalink)
how much does this usually run?
Old 02-20-2009, 07:27 PM   #7 (permalink)
gcozmo's Avatar
View gcozmo's Photo Gallery
I had a similar noise with my '97 with 106K miles. I just changed the sway bar bushings (Moog) and the sway bar end links (TRW) and that helped the noise a little ($120). Then while I was into it I just went ahead and changed the struts with the Monroe Quick Struts ( $200 each) which are a complete unit and took about 1 1/2 hours to do both. Doing both of these things has completely silenced the front end.
Greg
'97 Toyota Camry
'07 Ford F-150
gcozmo is offline   Reply With Quote
