I would pull the plugs and check there for oil burning. I'd also re-check the area under the timing belt cover for oil leak; that would show leaking seals that would be replaced anyway at TB change. Have you checked for leak at oil pan drain plug? I find your leakage excessive. After I did initial post purchase service work (TB, seals, etc.) my car does not loose/burn any oil between oil changes. I purchased my Camry with 138k on odometer.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
