Replacing rear licence plate bulbs? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-19-2009, 05:31 PM   #1 (permalink)
Togue superstar
t3chnique's Avatar
iTrader Score: 6 reviews
View t3chnique's Photo Gallery
which bulbs do I get from http://superbrightleds.com/led_prods.htm of I want to replace my license plate bulbs in the back?
I would like it to look similar to the new Lexuses, which have that bluish white effect.
Thanks
Just suspension and cosmedics.
t3chnique is offline   Reply With Quote
Old 02-19-2009, 06:23 PM   #2 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
There should be a link to the Sylvania bulb fitment guide on superbrightleds.com, otherwise you can Google for it. It's got ALL the bulbs that fit your car. The license plate bulbs are 168/194. I decided on the 5LED wide angle bulb in cool white for the license plate lights and warm white for the parking lights.
Gen 3.5
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
Old 02-19-2009, 10:17 PM   #3 (permalink)
TheKevin's Avatar
View TheKevin's Photo Gallery
get the 194/168 flank LEDs
TheKevin is offline   Reply With Quote
Old 02-19-2009, 10:46 PM   #4 (permalink)
Togue superstar
t3chnique's Avatar
to islandboy, what u mean the 5led? Were u revering to the brightness? Is there a 4?
Wide angle mean the 360 degree ones?
Sorry for the questions, im new to all this. Think u could link me directly to the single 4 brightness level ones. Wide angle is not necessary. I will be needing two of them in a cool white.
Toyota camry 2001.
mine also used the same wleds (168/194) as yours I think.
Old 02-19-2009, 10:47 PM   #5 (permalink)
cruisn76's Avatar
View cruisn76's Photo Gallery
^ better yet, get SMT leds. They spread the light so much better. In fact it looks better than Lexus ones.
I think some flanks come SMT. Either way looks nice at night.
92 Camry 4 cyl 5 Spd
390,000km, Retrofited Projectors + 6000k HID, 2500k Fogs, SRI, K-Sport Coilovers, TRD Rear Sway Bar, GEN4 Ralco Short Shifter, Alpine 7" IVA-D900, 2 x 10" MTX / MTX 900W Amp
cruisn76 is offline   Reply With Quote
Old 02-20-2009, 02:51 AM   #6 (permalink)
Togue superstar
t3chnique's Avatar
ic. think you could provide a link for them so I could check em out?
Old 02-20-2009, 07:58 AM   #7 (permalink)
on full afterburner
Gameroom cash: $1339397
you should check out v-leds.com for their "HID white" line of license plate lights as well.
they are a pretty close match to the Lexus lights as far as a plug and play solution goes.
Old 02-20-2009, 02:06 PM   #8 (permalink)
Togue superstar
t3chnique's Avatar
hmm which ones did you get cuz they look prety bright compared to the stock Lexus ones...
Old 02-20-2009, 06:10 PM   #9 (permalink)
on full afterburner
http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
Old 02-20-2009, 06:46 PM   #10 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
This is what I use. I got it from Superbrightleds.com
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 02-20-2009, 07:28 PM   #11 (permalink)
Togue superstar
t3chnique's Avatar
ok found those on the site. $4.95 each.
got a picture of how they look at night? I need just two correct?
Old 02-20-2009, 10:40 PM   #12 (permalink)
cruisn76's Avatar
These will do. Flank with SMT's. Make sure to pick up Cool White or 4300K
Reason I said get SMT's is because it is flat mounted and can provide 180 degrees light spread.
Old 02-20-2009, 11:04 PM   #13 (permalink)
Togue superstar
t3chnique's Avatar
btw crusin76, what are SMTs?
Old 02-20-2009, 11:18 PM   #14 (permalink)
cruisn76's Avatar
^ LEDS come in different form factor if you wanna call them that. SMT is called Surface Mount Technology. The LED does not protrude and is mounted flat. It has a light output of almost 180 degrees, so that provides good lighting.
If you want the really really good licence plate LED go with these.
A bit pricey @ 14.99 but it will even light up the floor. I have these and I have also gone through my share of LEDs. Around $200 worth so.
The flank one from superbright leds will do also but the light output from this link is awesome.
Old 02-20-2009, 11:20 PM   #15 (permalink)
cruisn76's Avatar
The link I provided for those leds are perfect for licence plates since it was designed to shoot the light downwards. When you remove the plastic housing to replace the led you will see what I mean. In comparison to the flank from superbrightleds the 6 SMT are scattered everywhere (left right top) so there is no concentration of light like the one from V-LEDS
