Timing Belt Replacement: Tips??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-21-2009, 11:32 PM   #1 (permalink)
View Poser's Photo Gallery
4th Generation Timing Belt Replacement: Tips???
Is it worth using all OEM parts??? Are there really good aftermarket kits??? I checked the usual suspects (advance, autozone...etc) and since they seem to be import-phobic, I was unimpressed. Can someone recommend a good place to get a complete Timing Belt Component Kit...(belt, tensioner, pulley, water pump, gaskets, seal). Looked on Ebay and found sh!te.
Any help and or suggestions would be greatly appreciated.
Poser is offline   Reply With Quote
Old 02-22-2009, 12:53 AM   #2 (permalink)
Gameroom cash: $303255
I would stick with OEM parts since this job is so labor intensive. I wouldn't want to have to do it again becuase some aftermarket part failed. You could try this source or any of the other OEM parts sources that support this forum by advertising here:
http://www.toyotapartsstore.com/
Mike
Old 02-22-2009, 01:15 AM   #3 (permalink)
Mike
Thanks Mike
