» Site Navigation
» Buyers Guide
» Network Links
3rd & 4th Generation (1992–1996 & 1997–2001) Toyota Camry Discussion for years: 1992-1996 & 1997-2001
02-22-2009, 12:52 PM
#1 (permalink )
camry bad acceleration & idle ??????
98 v6 camry
bad idel
loss of power and rpm when i accelrate
after 4000 rpm car will gain power as soon its under 4000 it will run slugish
cleaned egr
cleaned lower and upper intake manifold
cleand trottel boddy
any othe advise be very help full
02-22-2009, 01:54 PM
#2 (permalink )
seafoam?
02-22-2009, 03:18 PM
#3 (permalink )
iTrader Score: 13 reviews
Knock Sensor went bad.
Have a CEL?
My riced out crapmobile Camry:
http://www.cardomain.com/ride/228043...y-xle-sedan-4d
5 Lug Corolla WHAT?
02-22-2009, 03:40 PM
#4 (permalink )
Originally Posted by
ASG14
Have a CEL?
both knock sensors where bad had to replace them ...
now i dont get any error codes for them anymore sometimes ill get 115
but i assume this is a different problem with no codes im gone get seaform tomorow and try that
02-22-2009, 03:41 PM
#5 (permalink )
im not driving it right now to worryed i break some thing
02-22-2009, 03:43 PM
#6 (permalink )
115 is not an OBD2 error code.
So you blew both knock sensors, replaced them, and it still has the same problem?
5 Lug Corolla WHAT?
02-22-2009, 03:48 PM
#7 (permalink )
ASG14
sorry p0115
i fixed the knock sensor codes plus i have my tracking control back
but if i push down on the gas pedal (fast ) it will lose power and rpm ,gas pedal (slow) the engin will rev slowly up high until 4000 rpm and tyhen the car drives like it is suppose to but i have to keep rpm over 4000
so now im trying to fix this any help is appiciated
02-22-2009, 04:31 PM
#8 (permalink )
Check your hoses, it sounds like a vacuum leak.
At 4000RPM the engine need alot of air, so i think the leak will not be a problem anymore.
02-22-2009, 04:55 PM
#9 (permalink )
it may be a clogged cat. you can test for that by disconnecting the exhaust before the cat if possible and test driving it to see if that helps.
dave mc
02-22-2009, 05:28 PM
#10 (permalink )
davemac2
dave mc
new cat
02-22-2009, 05:32 PM
#11 (permalink )
When you replaced the knock sensors, what sensors did you replace then with?
This just sounds identicle to every time I blow a knock sensor (And I've blown 4 of then in about a year.....ugh).
Did this happen immediatly, or was it gradual?
5 Lug Corolla WHAT?
02-22-2009, 06:18 PM
#12 (permalink )
JJJJJJ
Learn English.
There is an old saying.....
If you nothing good to say you better dont say nothing at all !!!
#13 (permalink )
ASG14
I just have replaced them yesterday with brand new knock sensors i had the since 98 and this is my first major problem
02-22-2009, 06:26 PM
#14 (permalink )
p0115 is engine coolant temp sensor, and puts it in fail safe mode at 176F. So it;s not liek it;s running at start up temp.....
Is your CEL current on right now? If so, I'd go read the codes again, because the knock sensor code may have popped up again.
I honestly can't think of what else it could be.
5 Lug Corolla WHAT?
02-22-2009, 07:20 PM
#15 (permalink )
ASG14
no codes as of now
i wish i knew
Linear Mode
