Sound Advice? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-24-2009, 02:31 AM   #1 (permalink)
Clean Gen4
View Camry_guy's Photo Gallery
Sound Advice?
Hey well ive gone through a few subs in the past 6months but i think i found a sub i wanna stick with...atleast for now lol but i need some advice!! I just purchased a JL 12w7 and i had a box built to spec but its not carpeted yet, anyone from toronto know where i can get it carpeted? also im not sure if i need a capacitor at this point and if so, what would be the best farad rating to use, or even if it makes more sense to just put a battery in the trunk...its currently running from my Phoenix Gold Ryval 8001 monoblock amp which should push somewhere around 700WRMS to the sub so i know its drawing alot of power, any suggestions? also anyone know where i can get some 7" headrest monitors that wont fall apart when installing like what happened to one of my friends lol Thanks!
Camry_guy is offline   Reply With Quote
Old 02-24-2009, 12:56 PM   #2 (permalink)
View frojoe's Photo Gallery
Buy some carpet and some 3m spray adhesive and carpet it yourself, it wouldn't be hard. I would suggest not getting a capacitor. Have you done the big 3 yet? If not do that before anything else.
frojoe is offline   Reply With Quote
Old 02-24-2009, 03:55 PM   #3 (permalink)
Clean Gen4
umm whats the big 3? lol
Old 02-24-2009, 03:57 PM   #4 (permalink)
View Manny1337's Photo Gallery
yea i agree with fro. get some 0/1 gauge power and ground wire running to that thing. and doing the carpet yourself is very easy and cheap.
Manny1337 is offline   Reply With Quote
Old 02-24-2009, 04:00 PM   #5 (permalink)
Clean Gen4
Yea ive already got 0/1 gauge wires running to it i was just wondering ab out a cap lol y would u suggest not getting one?
Old 02-24-2009, 04:13 PM   #6 (permalink)
it dosent really do anything. unless you want to listen to your music when the car is off but other than that it is useless :x
Old 02-24-2009, 04:17 PM   #7 (permalink)
Clean Gen4
oh lol then thats a waste i never listen to it with the car off thanks for the help!
Old 02-24-2009, 04:33 PM   #8 (permalink)
haha yeah i was also thinking of getting one till i did some research on it and found out it does nothing.
Old 02-24-2009, 04:48 PM   #9 (permalink)
Clean Gen4
lol yeah i had alot of people say get it it will help with the dimming lights and then some that said it would do anythin
Old 02-24-2009, 05:14 PM   #10 (permalink)
If you go on car audio forums such as the 12volt the genera consensus from the pros is almost always that caps are a waste of money. I've also seen an physicist write an explanation of why they can not work. Some people say they help, but the only time I believe they help is not a problem in toyota's, so skip the cap.
As far as the big 3, its running the same 0/1 awg wire that you sent to the trunk for the 3 major wires under the hood. The Alternator to battery positive, the battery negative to chassis, and the alternator negative to chassis. Running 0/1 awg to the trunk is useless if the wire from the alternator to battery is like 8 or 10 gauge. Here is a link to a thread where I have pictures of my big three, just scroll down a bit. The big three is a must before any other upgrades to your electrical system. If you need any other help with it I have more pics I can post.
P.S. Don't forget the fuses, they are really important.
Old 02-24-2009, 06:18 PM   #11 (permalink)
View finfinder's Photo Gallery
I'm pretty sure there is a tutorial on carpeting a box on the Elementaldesigns.com website.
I'd do an alternator upgrade if you are having headlight dimming issues.
finfinder is offline   Reply With Quote
Old 02-24-2009, 10:09 PM   #12 (permalink)
Clean Gen4
Thanks for the input ill try and do the big 3 as soon as i can and hopefully that will help because EVERY light in my car including my HID's dim, even my dome light almost goes completely out xD and as for fuses, i have all stinger 60amp i believe, 1 near the battery for the 0/1 gauge wiring and then 2 in the trunk where i split the power wire to my 2 amps (1 4channel for my interior mids/highs) and i used all stinger accessories
Old 02-24-2009, 11:11 PM   #13 (permalink)
As far as the fuses that's perfect for now. When you do the big 3 however, add another fuse between the alternator positive and battery positive. Both that fuse and the stinger you already have should be as close to the battery as possible, I'd say more than a foot away is too far.
It seems like so far you've used high quality parts and taken the time to do it right, so I think you'll really notice an improvement from the big 3. It may not be enough however, and if you really want all that power you might need a high output alternator.
An example: my camry has a 70 amp alternator, and that's at 14 volts 70x14=980 total watts. This is split between all other electrical components in your car, and whats left is further reduced by the amplifier efficiency of around 80% for the mono if its class d, leaving less than 700 watts available. You also need some power for your 4 channel that's more like 60% efficient.
Do the big 3 first, and then if your not satisfied you shoudl probably not waste money on a capacitor or battery, and just buy a h.o. alternator.
Old 02-25-2009, 06:54 AM   #14 (permalink)
i was just wondering because i have the same problem. how many amps is a 98 camry le 2.2 alternator?
1998 Camry I4 2.2 Currently: 110k
Alpine Ida-x100, Polk Momo 6x9 (Rear), Polk DB651 (Front), Infinity Reference 475a, AudioQ Aq-1200, 4 Re X 8's <-- yes she slams
Old 02-25-2009, 11:33 AM   #15 (permalink)
groovemasterodi's Avatar
View groovemasterodi's Photo Gallery
80 I believe.
I dropped two 60 amp-draw amps on mine. Gotta get off my ass and do the big 3
2001 Camry..5FSE..
groovemasterodi is offline   Reply With Quote
