93 Camry Acceleration Improvment? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-26-2009, 03:43 PM   #1 (permalink)
View gaervin's Photo Gallery
3rd Generation 93 Camry Acceleration Improvment?
Are there any easy methods or parts available for improving the performance of the Camry XLE V6? This thing is a bit of a dog until the RPMs are pretty high, then it sort of takes off until the transmision upshifts, then the slow acceleration starts over again.
gaervin is offline   Reply With Quote
Old 02-26-2009, 05:06 PM   #2 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $284080
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
advance the timing, suspension (a lot of money for minimal gain) or a transmission swap.....that one usually does the trick
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 02-26-2009, 05:17 PM   #3 (permalink)
View aznstylez's Photo Gallery
What's the mileage on it? Ever gave it a tune-up? Change spark plugs, spark wires, change coolant, change transmission oil, and change motor oil. Check the timing on the car, advance the throttle cable...etc.
aznstylez is offline   Reply With Quote
Old 02-26-2009, 05:58 PM   #4 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
well your lucky since your motor(3vz-fe) can squeez a little power out fairly easily. thinkgs liek enlarging and reworking teh Y-pipe, highflow cat, a tuner and a tune can free up some ponies. however the 3vz usually has more power down low so you may want to perform a tunup if ya havnt already. also check these out.
http://www.toyotatuners.com/forum/showthread.php?t=158
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 02-26-2009, 06:00 PM   #5 (permalink)
The car has about 60K on it. At 40K I had to replace the valve cover gaskets. It's a V6, so while I had the engine half dismantled I replaced the spark plugs, timing belt, and camshaft seals. Not much else since then, other than routine maintenance and oil changes and such.
Old 02-26-2009, 06:26 PM   #6 (permalink)
Thanks for the link! I like the cable adjustment idea, and also the air intake mod!
Old 02-26-2009, 10:43 PM   #7 (permalink)
norcalcam's Avatar
View norcalcam's Photo Gallery
ya thats a good link i remember seeing that a while ago and trying to adjust that transmission cable thing for quicker shifts but im not sure which way to go? do i put more thread or less thread?
93 3VZ-FE,WEAPON-R INTAKE,MAGNAFLOW DUALTIP,17'S,FRONT STRUT BAR,AND LOWERED 1.3 INCHES ON H&R SPRINGS
norcalcam is offline   Reply With Quote
