Jacking points - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-28-2009, 05:05 PM   #1 (permalink)
v6camrydriver's Avatar
View v6camrydriver's Photo Gallery
3rd Generation Jacking points
Can I jack the car up using the side frame rail below the b piller (between the two main side jacking points)?
v6camrydriver is offline   Reply With Quote
Old 02-28-2009, 06:36 PM   #2 (permalink)
View toyomoho's Photo Gallery
If you go this route place a 2x4 between the jack and chassis or you may bend the edge of the rail a little.
Old 02-28-2009, 07:40 PM   #3 (permalink)
Cool thanks!!
Old 02-28-2009, 07:46 PM   #4 (permalink)
Make it a long 2 x4 to distribute the weight of the car over a longer area.
Old 03-01-2009, 08:41 AM   #5 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
I would recommend uses a Skill saw to cut a slit down the center of the 2x? wide and deep enough to allow the rail to fit down in. That way there is no chance to bend the rail and no chance of slipping off.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 03-02-2009, 01:21 PM   #6 (permalink)
View Risran's Photo Gallery
thanks guys i was wondering the same thing
Risran is offline   Reply With Quote
