what tool to hold crank pulley - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-02-2009, 10:59 AM   #1 (permalink)
View aye87's Photo Gallery
hi, what do you use for holding the crank pulley while loosening the bolt?
im on low budge so any help would be great
thank you
aye87 is offline   Reply With Quote
Old 03-02-2009, 11:10 AM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
I have not seen an aftermarket tool for this. I ended up making my own with torch and welder. For removal you can use the starter bump method. Use a breaker bar with 6 point socket and put on crank bolt with bar resting on the ground to keep it from turning. Make sure breaker bar is on right side so that starter will loosen bolt, not tighten it. Engine turns CW. Unplug the spark plug wires so car will not start and turn the ignition to start for a split second. The starter should loosen the crank bolt enough for you to turn it off. I've done this and it works pretty slick. You will still have a problem on re-assembly as you'll need to hold the pully/crank still to torque to proper value. Not sure what others use but you can use an impact gun as well.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 03-02-2009, 11:32 AM   #3 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
i second the starter bump method.
Old 03-03-2009, 04:29 PM   #4 (permalink)
Gameroom cash: $105400
View dz63's Photo Gallery
Click on this link and scroll down to post #15 for a couple Youtube videos of the "starter blip" method.
Timing Belt Help.
2002 Camry 2.4L Auto - 70K miles
2008 Corolla 1.8L Auto - 48K miles
dz63 is offline   Reply With Quote
Old 03-03-2009, 05:24 PM   #5 (permalink)
View toyomoho's Photo Gallery
Get a 1x4 board. Drill two holes to attach it to the pulley using the threaded bolt holes on its face. Drill a larger hole between the two holes to allow access the socket used to turn the bolt. Make the board long enough that when the crank pulley turns it will bind up with the floor.
Old 03-03-2009, 07:54 PM   #6 (permalink)
View Poser's Photo Gallery
starter blip did the trick for me... and I was trying to fab things for days.
Poser is offline   Reply With Quote
Old 03-03-2009, 08:52 PM   #7 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Breaker bar on control arm and bumpstart.
You know, I was ABOUT to say that, thinking it was the Cam he needed too, lol. But I just realized it's the Crank.
5 Lug Corolla WHAT?
Old 03-06-2009, 08:40 AM   #8 (permalink)
A stock Camry? Blasphemy!
Gibson99's Avatar
View Gibson99's Photo Gallery
If my impact won't remove it, I use a chain wrench to hold the pulley from turning. Since they're usually overtorqued when I do it this way, it leaves dents in the grooves of the pulley, so you have to file them smooth again, but that's trivial really.
http://buy1.snapon.com/catalog/item....re&dir=catalog
that's a small version of what I use. I got one that has a handle almost 3 ft long, so it's easy to brace it against the floor or a motor mount when loosening the crank bolt, and against the radiator support (or floor) when tightening. mine cost about $15 at harbor freight but for some reason i can't find it on their website.
98 Camry CE v6 5s
97 MX-5
95 Camry SE v6 2dr SC (sold)
www.gibson99.com
Gibson99 is offline   Reply With Quote
