Lighter has no power 94 Camry V6 XLE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-02-2009, 02:59 PM   #1 (permalink)
iratoyota's Avatar
View iratoyota's Photo Gallery
3rd Generation Lighter has no power 94 Camry V6 XLE
My cigarette lighter does not supply any power to my cell phone charger or my GPS adapters. Any help or advice would be great ! Thank you. Please help.
iratoyota is offline   Reply With Quote
Old 03-02-2009, 04:06 PM   #2 (permalink)
View toyomoho's Photo Gallery
Check Cig/Radio fuse.
Old 03-02-2009, 04:36 PM   #3 (permalink)
iratoyota's Avatar
that was my 1st inclination but the all the accessories and the radio with power antennae work perfect. also the cruise control works fine as well !
Old 03-02-2009, 05:16 PM   #4 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Replace the Cig lighter. Or just take it out (the U trim) and see if the wires are all connected/
5 Lug Corolla WHAT?
Old 03-02-2009, 05:20 PM   #5 (permalink)
If the clock works OK, the fuse is OK. If fuse OK the issue is the wiring or the lighter itself.
Old 03-02-2009, 05:57 PM   #6 (permalink)
TexanF250's Avatar
View TexanF250's Photo Gallery
The plugs for the power supply are slightly larger than the cig. lighters. Sometimes they will work, other times they will not. I would use either a multi meter or a known to be good cig lighter to check for voltage.power to the lighter receptical. You may not have a problem with the lighter receptical, it could be the plug from your cell phone won't work in the smaler cig. lighter receptical.
TexanF250 is offline   Reply With Quote
Old 03-02-2009, 07:43 PM   #7 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $284080
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
I had that issue once.....damn you charger!
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
