Air intake temp sensor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-04-2009, 04:37 PM   #1 (permalink)
View knfenimore's Photo Gallery
Hello
I have a 99 Camry V6. Lately the cold idle is very high. Once it warms up it goes down to normal. I thought it was the Air intake Temp senor, but I can not find where it is located. I would have thought in the air intake box or rubber intake to the intake manifold. The part looks like a black plastic probe with a 2 pin connection. Can anyone help with this?
Thanks
Keith
knfenimore is offline   Reply With Quote
Old 03-04-2009, 05:05 PM   #2 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
the IAT sensor doesnt really control your idle ... so if theres a cold start idle issue, its gonna be a different sensor altogether
but first, how high is it idling exactly? and what was the outside temperature? because it could be normal ...
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 03-05-2009, 09:58 AM   #3 (permalink)
View FireFire's Photo Gallery
there is coolant temp sensor just locate beside the enginee. At the end of outgoing coolant pipe.
FireFire is offline   Reply With Quote
Old 03-05-2009, 10:04 AM   #4 (permalink)
View Manny1337's Photo Gallery
i believe thats what the car is supposed to do. mine also does it. when its cold out the idle runs at about 2k as the car warm up it drops to 500.
1998 Camry I4 2.2 Currently: 110k
Alpine Ida-x100, Polk Momo 6x9 (Rear), Polk DB651 (Front), Infinity Reference 475a, AudioQ Aq-1200, 4 Re X 8's <-- yes she slams
Manny1337 is offline   Reply With Quote
Old 03-05-2009, 12:52 PM   #5 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
Originally Posted by knfenimore View Post
Hello
Thanks
Keith
Its probably because its been colder outside in the morning. So long as its not climbing above 2000 rpm, it's normal. So long as your idle returns to normal after it warms up and you don't have a CEL, I wouldn't go looking for a problem.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
Old 03-05-2009, 01:31 PM   #6 (permalink)
Idle
The car is parked in the garage at around 58deg. It goes t0 1900 and drops to 600 when warm. It just seems high compared to what it used to do. My new Camry is 1500 and drops to 600 when warm. If this is Ok' ill leave it alone. What does trigger cold high idle rpm?
Thanks
Keith
Old 03-05-2009, 01:41 PM   #7 (permalink)
Certifiably Insane
96paseo's Avatar
Thanks
Keith
The engine coolant temp sensor and IAC are responsible for how your car idles cold. The ECT sensor tells the ECU to send more fuel (when cold) and the IAC regulates the amount of air going into the throttle body.
Old 03-05-2009, 01:53 PM   #8 (permalink)
thats normal for that year camry =P
Old 03-05-2009, 05:07 PM   #9 (permalink)
Temp
Thanks for the replys
Keith
