Swapping Stock Radio Compatibility - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-04-2009, 07:01 PM   #1 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
4th Generation Swapping Stock Radio Compatibility
Hi, This is my first post here.
I have a 98 LE and have the radio/cassette single din combo. It looks like this one http://cgi.ebay.com/ebaymotors/98-99...fAudioQ5fVideo
I found a 99 camry LE part out that has a nicer cd/radio/cassette and doesnt have the little shelf under it. I think it looks like this one http://cgi.ebay.com/ebaymotors/TOYOT...fAudioQ5fVideo
Has anyone done a swap like this or know if its possible? The camry I can get the radio out of has tweeters in the door and mine doesnt. I hear theres a factory amp in the ones with the tweeters? I looked around for the amp in my 98 but couldent find it.
Will the connections match up and if i do need to run the factory amp how hard would it be to wire it up?
carsrus is offline   Reply With Quote
Old 03-04-2009, 08:16 PM   #2 (permalink)
View toyomoho's Photo Gallery
If the car has an amp it may be behind the passengers side upper kick panel.
Old 03-04-2009, 09:50 PM   #3 (permalink)
TexanF250's Avatar
View TexanF250's Photo Gallery
http://installdr.com/InstallDocs/Toyota/PDF/869037.pdf
The above link may be of some help to you.
TexanF250 is offline   Reply With Quote
Old 03-07-2009, 05:21 PM   #4 (permalink)
I just swapped these radios and they swap perfectly fine. The 99 LE with tweeters in the door doesnt have an amp so it was a simple swap that took 20 min. The connectors match up its just a simple bolt in. If your also in there you can change the bulbs behind the AC controls. Theres 2 #74 bulbs. Just an FYI the ones I got at autozone were a soso squeeze inside the socket so I would try getting them somewhere else.
Thanks for the replies guys.
Old 03-08-2009, 10:29 AM   #5 (permalink)
TexanF250's Avatar
Thanks for posting the resolution. It will help someone else down the road.
