Hi,
I have a 1997 camry. The engine knocks when I press the gas. When I first start the engine, it idles fine- makes no noise what so ever. The sound is not a hard knock, but I do believe it is in the block. Is there a way to check this Before I change the whole motor .
Hi,
Mine is not 100% solved yet, but the problem improves greatly if I use high octane gas. It also improved a bit after I sea foamed the engine. That tells me it's not mechanical. Why would a mechanical problem disappear when I use 93 octane and return when I use 87? I was thinking about replacing the knock sensor next since that's what controls timing on my generation engine. Your year is a bit different than my 2000. Good Luck.
I replaced the knock sensor this week without any improvement. Not suprizing since there was no sensor error coded, but I decided to try it.
I've done some more research and I'm wondering if my ping could be related to my timing belt change that was done around the same time as the ping first appeared. It was done by the dealer and you normally assume if the car is running ok, that they've done the job right. But I've read other threads for differnt type cars that developed a ping when a new belt was installed just one notch or tooth off. If I find out, I'll post the results.
The mechanic could have over-advanced the ignition timing.
Pinging, pre-detonation or 'engine knock' usually only occurs during load, so it is most probably pre-detonation. A quick fix would be to run higher octane fuel.
Edit: Okay, just read your 2 previous posts and yes, definitely a case of pinging. Higher octane ratings correlate to higher activation energies. Activation energy is the amount of energy necessary to start a chemical reaction. Since higher octane fuels have higher activation energies, it is less likely that a given compression will cause detonation.That's why you use it in high performance' engines to prevent detonation(engine knocking or pinging) due to the high compression ratios.
Would they have done that by way of the belt placement, or is there another way to adjust timing on my 2000 5S-FE engine?
I'm definitely aware that excessive ping is a bad thing and that's why I'm on a hunt to solve it. The higher octane helps, but I'm after the complete cure.
Would they have done that by way of the belt placement, or is there another way to adjust timing on my 2000 5S-FE engine? Plaz
To check timing, you should use a timing light. Put 'white-out' dots on the crank pulley and check the light turn on when it passes the correct point. I'm not sure what it should exactly be set for gen 3/4's are, but my Gen 2 is 10*BTDC. You also have to jump terminals in the diagnosis connector to stop the ignition system from advancing or retarding the timing.
If it's not correct you'll have to open the distributor and adjust the spark timing.
