Keep or Junk, the unsolvable problem
1995 camry, a/t I4.
Transmission: ok.
TPS: ok.
Coils: ok.
Dist/cap/rotor: ok.
Wires n plugs: ok.
compression: ok.
Vaccuum: ok, no leaks could be found after being under the hood for days on end.
O2's: ok.
EGR: ok.
Timing and timing belt = ok.
Car hesitates with little acceleration until you floor it. Car did idle but needle was up and down. After taking off the IAC now the idle is about 2000 so I think I broke it. Map sensor is last thing to really check, trying to avoid that because that and the IAC will cost more than the car is worth.
Forgot to mention, throws codes 25/26. Rich mixture/Lean mixture.
What do you think the Trade in value would be at fair condition?
