'95 Camry - slight bump when accelerating from stop - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-08-2009, 12:04 PM   #1 (permalink)
View JoeD1075's Photo Gallery
Just wondering if anyone else out there ever ran into this. When I am at a dead stop with my 1995 camry and hit the accelerator a little hard, I feel a slight bump as it takes off. It sounds a little like a suspension issue, but I can't rule out the transmission or engine mounts (the mounts LOOK good but that may not mean they are not bad). The car has 107K miles on it.
Any ideas?
Thanks in advance
JoeD1075 is offline   Reply With Quote
Old 03-08-2009, 12:19 PM   #2 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
what side of the car do you feel it?
Old 03-08-2009, 12:38 PM   #3 (permalink)
EverReady's Avatar
View EverReady's Photo Gallery
If what I experience is normal from spinning tires..
Could just be your tires slipping, as there is alot of "bumping" when I try to hammer on the gas off a stop.
EverReady is offline   Reply With Quote
Old 03-09-2009, 12:55 AM   #4 (permalink)
View finfinder's Photo Gallery
My first guess for that mileage would be the engine mounts.
Try this, with the car in park and the hood up, put your foot on the brake and watch the engine when you keep your one foot on the brake and put the car in drive and tap the accelerator with the other foot. Watch and see if the engine tilts hard forward. It should move a little. If it moves a lot and you feel the thump then your mounts are gone. You mileage is about the same as mine when I needed new mounts and had the same symptom.
finfinder is offline   Reply With Quote
Old 03-09-2009, 01:40 AM   #5 (permalink)
Gameroom cash: $844300
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Front engine mount, the one right under the exhaust header. It;s really common and happened on my old '92 Camry,
'95 Corolla AE101...
