Oil issues
Well seems since I've been driving differently the last couple weeks I've noticed I've been using more oil.
When the car has been sitting a spell, and I start it, I get bluish exhaust, then it stops. Initially it started doing this after I seafoamed the engine. It doesn't always do this, but does on a fairly regular basis. I now there is a few leaks, some I've fixed due to seals going, so some is more than likely leaking out, although there's no tell-tale signs on the driveway at all.
I've been afraid of a head gasket, but to be honest, I've been keeping an eye on the oil and coolant, and I've not seen any signs that it's an issue. I do probably need to do my timing belt and seals as I've no idea when they were last done on the car.
Anyone have any ideas? Things I should watch out for? The only thing I am sure of is I use oil, and if I'm going higher highway speeds, I use more than if I go say 80km/h highway speeds.
TIA
