Spark Plugs/Wires - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-09-2009, 10:44 PM   #1 (permalink)
View Manny1337's Photo Gallery
4th Generation Spark Plugs/Wires
I gave my car a tune up not too along ago >10k. I used bosch wires and plugs and i seen a couple people say bad things about the wires. Is there any real problem. Am i losing any real power from my car? Just looking for some input. Thanks guys
1998 Camry I4 2.2 Currently: 110k
Alpine Ida-x100, Polk Momo 6x9 (Rear), Polk DB651 (Front), Infinity Reference 475a, AudioQ Aq-1200, 4 Re X 8's <-- yes she slams
Manny1337 is offline   Reply With Quote
Old 03-09-2009, 10:56 PM   #2 (permalink)
just a nobody
Probably have more to do with their longevity than how they work; work for a short time and then start having different kinds of problems.
N.E.O.
Old 03-09-2009, 11:52 PM   #3 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
I never really heard of people having issues on the Bosch wires, just the plugs. Both 2WickedToyz and BigBird this year had thier Bosch plugs take a dump. BigBird had one with cracked porcelain.
5 Lug Corolla WHAT?
Old 03-10-2009, 06:22 AM   #4 (permalink)
on full afterburner
Gameroom cash: $1339697
stick with Denso or NGK
Old 03-10-2009, 09:45 AM   #5 (permalink)
View mvftw's Photo Gallery
mvftw is offline   Reply With Quote
Old 03-10-2009, 12:41 PM   #6 (permalink)
yeah thats what ive heard. is there any online store thats cheaper than going to an autostore for the plugs maybe even the wires if they are good price
Old 03-10-2009, 01:28 PM   #7 (permalink)
View sr5punk's Photo Gallery
4th Generation
best place I found for ngk wires is sparkplugs.com. they will run you about $40.00 shipped to your door. the part number you want for the 5sfe is TE58. Just got them installed over the weekend. best place to get plugs is probably the local store. i just got some ngk g-power plugs. they are doing ok so far. i got a check engine light after installing, but its probably just loose on one of the plugs. plugs ran about 13 for all 4. not the iridium 9 but i aint racing or nothing. hope this helped.
sr5punk is offline   Reply With Quote
Old 03-10-2009, 01:34 PM   #8 (permalink)
4th Generation
ps.
i had some lame-o bosch plugs that came out totally wasted. i mean there was nothing there. and the wires were some off brand too. max spark or some garbage like that. needless to say one of the rubber boots from those lovely wire got stuck on top of my awesome bosch plug. i spent and hour and a half getting it out of the plug well. it was great.
Old 03-10-2009, 08:43 PM   #9 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
If it's a Gen 4, it's better to get the double platinum plugs with two side electrodes since you have the waste spark ignition system. The plugs run about $6-8 each depending on where you get them.
The G power plugs will work, but they won't last as long. Not as much an issue compared to the V6 but it's less time you spend changing plugs
2007 Camry 2.4L 5M
Old 03-11-2009, 01:53 AM   #10 (permalink)
yeah the first time i bought the plugs i got single side electrodes and the car didnt have as much power i could tell something wasnt right. i looked it up and they were the wrong ones so i replaced with the double and it was back to normal =P
Old 03-11-2009, 06:09 AM   #11 (permalink)
View Albetime's Photo Gallery
4th Generation
I had Bosch wires and plugs installed when I overhauled my engine, sorry but its all stock. Well after approximately 20k miles I developed a slight miss fire, I assumed it was a coil pack since these were original with 165k miles. Well as soon as I pulled NR 3 wire I could see it was one of my 2 problems, NR 2 wire also failed. I had to put the original wires back on just to get to the parts store where they at least replaced the set without charge. As far as Bosch plugs, never had any issues with them. 1997 Camry 2.2 Auto
Albetime is offline   Reply With Quote
Old 03-11-2009, 11:51 AM   #12 (permalink)
1999 Camry LE 1mz-fe
View 937309.romero's Photo Gallery
4th Generation NGK IRIDIUM IX in 1999 1MZ Camry
These are the plugs im using in my 1mz 99 camry works great no super power out the gate difference but i can tell something is better after the install.
937309.romero is offline   Reply With Quote
Old 03-11-2009, 01:26 PM   #13 (permalink)
4th Generation
oh I see. hmmm I wonder if that may be the reason why I still have a code on the car,. I did not know this. thanks for the info. Sorry to hijack the thread, but what is the waste spark ignition system touring camry? pm me if you can about it. thanks!
Old 03-11-2009, 06:55 PM   #14 (permalink)
Using a plug with a single ground should not cause anything bad. The plugs just don't last as long.
Waste spark means each plug fires twice during each 4 stroke cycle so one spark is "wasted." The car only has 2 coils and each one is connected to two plugs so the plug will fire twice during the cycle. The way the circuit is arranged, it will fire from center to side and side to center which is why the OEM plugs have platinum chips on the side and center electrodes. Since the plug fires twice as often, two side electrodes are used to prolong the service life of the plug.
Plugs that only have platinum on one electrode will erode faster than normal due to the side to center firing.
2007 Camry 2.4L 5M
Old 03-11-2009, 08:21 PM   #15 (permalink)
Mr.Nutcase's Avatar
View Mr.Nutcase's Photo Gallery
Jap cars do not like Bosch. Stick to NGK or Nippo Denso
ECT,EGR,TPS,MAF,CMP,CKP,02,
Mr.Nutcase is offline   Reply With Quote
