Ignition Coil Location on a 1992 Camry 2.2L - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-10-2009, 09:26 AM   #1 (permalink)
View 92camryy's Photo Gallery
3rd Generation Ignition Coil Location on a 1992 Camry 2.2L
Hey guys I was going to test my Ignition Coil but I can't find the damn thing. Usually I see external coils but is this one built into the distributor? If so are both the primary and secondary inside of it? Any location info would be extremely helpful.
Its a 4 cylinder so obviously there are 4 spark plug wires going to the cap, and none to an ignition coil. Just 4 plugs connected to the distributor. There are also 2 wire harness connections going to the distributor. One is on the upper left corner with 4 wires and the other is mounted to the right middle side with 2 wires.
92camryy is offline   Reply With Quote
Old 03-10-2009, 10:06 AM   #2 (permalink)
I found this picture on the forums, but I have no experience with internal ignition coils... Would anyone be able to point out to me which part is the primary and which is the secondary?
Edit: Deleted photo so the loading time is lower
Old 03-10-2009, 11:35 AM   #3 (permalink)
Found it and removed it.
