Problem with the climate control panel lights in a 1997 Toyota Camry?
Tried to make a more entertaining title, but it's hard to explain in detail about what is wrong with my car. Anyhow, it is more of a pet peeve of mine than anything to be concerned about. When I turn the lights on in my car I can only see one side lighting up on the control panel under my stereo. Here are some pictures:
The first picture is just to show where it is I guess. Really can't tell what's wrong with the flash on.
If you have any ideas what may be wrong I'm all ears...
I guess I just need to know where to start. If it is a replacement bulb I need, where would I start or go to find one?
1997 Camry I4 2.2L 5SFE 185K Miles
1991 Camry I4 2.0L 3SFE 258K Miles
Thanks abew. Turns out it was a much easier fix that I had anticipated.
This was after taking off the plastic surrounding cover.
After removing the rotary knobs take the screws where the arrow is pointed at. The white markings up top are just to note that there are two clips that also hold the faceplate in. One should be able to take faceplate off easily after you release the clips and all three knobs and screws are removed.
There are two light bulbs on each side, obviously in my case the one on the left had burned out. They're simple bulbs to replace, but it may be difficult to find the exact one. I purchased Code number (74) from Advance Auto Parts and pulled the metal connectors out slightly from the bulb so they would be able to connect within.
Sorry I didn't post any pictures of what it looks like behind the faceplate, this was after I was putting it back together and I just remembered that someone might need it later. Fortunately, it is a very simple job to do.
Anyways, back to normalcy =)
I had the same problem and fixed it just like you did with the same bulb from the same place. I did the repair about 3 weeks ago and I have the same bulb out again so I guess I will be taking mine apart again. I hope that I just didn't get the bulb in there good and reseating it will fix it.
__________________ Greg
'97 Toyota Camry
'07 Ford F-150
Yes, the bulb for the cigarette light does come out, although I cannot remember how I did it. I replaced the one for the cigarette tray as well, though that was not hard at all.
The Following User Says Thank You to wdanlee For This Useful Post:
I have the same problem except when I move around the temperature dial the light comes back on.
The bulb is either loose or needs to be replaced.
'07 Honda Ruckus Big Bore TOTALED: '03 Ford Expedition Eddie Bauer 4x4 5.4L, '96 Camry LE 5S May '10: '11 Sienna V6 XLE FWD 8-pass. July '10: '06 Matrix XR Auto FWD Oct. '09: '05 RAV-4 L 4WD
ok, I tried but failed.
after removing the screws from the knobs, I noticed I couldn't remove the face becasue the switch from above (to switch between close and open for the cabin air) was on the way.
In order to remove the face plate from the AC unit. I need to take out that little switch. How did you do that?
Yup. Grab and pull. There's two pieces that come out. The lever itself, then a clear plastic piece that transmits the light. DON'T LOSE IT and remember which way it goes.
Just fixed it last night, with some pictures and additional info.
be careful when removing the top switch (the one above the 3 big knobs). It has a long clear plastic in there so light can go through. Pulling by force may damage that part. If you look behind the switch, you can use a screw driver to slowly pull it (there is a little gap in between)
Here is the part number for the bulb
How it looks like, ($5.50 from the dealer) NEw one on the left, just reuse the green cap
Final result
The Following 2 Users Say Thank You to grandpapa For This Useful Post:
grandpa - Thanks for that p/n! The dipstick behind the parts counter at a Toyota dealer near me couldn't find it. He tried to convince me I had to buy the whole assembly to get the light bulbs. I gave him my best "WTF!?!?!" look and said "you gotta be kiddin' me!!" and walked out.
